14 bolt full floater locker For sale
14 bolt 4.10 factory locker For Sale complete drum to drum with good brakes was completely rebuilt by gm driveline tech 25k ago it has 3/4 ton springs and lift blocks still bolted on sell the whole deal $200.00
perfect working order. can deliver within 20-30 miles or so. In Pa 17329 zip |
i'm guessing that factory locker is a gov-lock and not a detroit locker, correct?
forgot to add that if its a detroit, I would be interested.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 11-27-2004 at 02:54 PM. |
i can take the cover off and check do you have a pic of both so i can compare it to be sure im correct?
I will have to look for pictures, but if it has a d/l it should have 4-5 holes in the carrier, and you can see the detroit thru these holes.
if its a gov-lock there wont be any holes in the carrier.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
ok will check now and post back in 5-10 min
i may be able to snap a pi also |
here are pics of the 2 different diff's...
#1 is the gov lock #2 is the detroit
I would assume it's #2 you will need a new cover gasket now it tore taking it off but they are cheep.
PM sent
Still avalible currently.
i thought full floaters were 1 ton only? i might have a buyer for this let me ask him. also how much play is there in it?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
it is very tight rebuilt just 25k ago, so like new inside .
SOLD
1969 GMC thanks all who asked |
looks open to me, GM didnt offer Detroits from the factory unless it was a CUCV.
if you look at the pics, there is definitely some type of locker in the carrier....no spider gears visible. i have an eaton with a detroit in it, and it looks the exact same way thru the carrier.
#15 |
here is what an open carrier would look like, note the spider gear:
