11-27-2004, 09:16 PM | #1 |
engine placement
Have a 69 GMC 1 ton. Soon to pull the 350 out and go to a 400sb. Also going to put TBI on it with the serpentine belt set-up. I think the serp set up pushes the fan forward about 1 to 1.5'' forward. My thoughts are to use the big block towers which will allow the use of the heavier duty motor mount. Will this put the engine back for the fan placement?
11-27-2004, 10:03 PM | #2 |
Got Light Emitting Diode?
i thought that sb and bb mounts were the same, except for a dip in them for the manafolds??? if that were true you could use bb mounts on a small block
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
11-27-2004, 10:38 PM | #3 |
Recovering 67-72 Addict
I agree with 68w/sbc406. I am not sure that changing the motor towers is going to change engine placement. the solution might be as simple as not running a fan spacer to gain back fan depth in the shroud. If it still pushes the fan too deep you might be able to run a big block shroud which would also allow the use of a bigger fan blade.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
11-27-2004, 10:50 PM | #4 |
Watch out for your cornhole !
set it on 6 cylinder stands in the rear holes.
Problem solved....
11-27-2004, 11:46 PM | #5 |
The set-up I have with the serp belt is a fan clutch. I like the idea of the BB shroud, that may work out just right--won't have to move the trans then.
