Old 11-29-2004, 12:50 AM   #1
WB72
Before and After
WB72's Avatar
Choke decisions
I will be building a new small block, and just wondering about the choke. I live in Canada and the truck will be driven only in the summer. The exhisting quadrajet has the choke that has the bimetalic spring built in the intake maifold. I will be purchasing the RPM performer and a carb from Edelbrock.
Does the choke mechanism have any effect on how the carb functions normally?
Is the electric choke the most common?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 11-29-2004, 08:54 AM   #2
JimKshortstep4x4
Smile
The stock bimetallic spring choke setup works somewhat but the electric chokes work better. The stock chokes don't warm up fast enough in cold weather and stay on longer than they should. I would recommend the electric choke as it will open up faster and is more reliable.
Jim
Old 11-29-2004, 09:08 AM   #3
1969K10
1969K10's Avatar
Give up on both of them, and put in a manual choke
1969K10 is offline   Reply With Quote
Old 11-30-2004, 12:17 AM   #4
4x4Poet
Originally Posted by JimKshortstep4x4
The stock bimetallic spring choke setup works somewhat but the electric chokes work better. The stock chokes don't warm up fast enough in cold weather and stay on longer than they should...
Would you please speak to how well you think a new spring & lever functions on a freshly rebuilt OEM carb, vice a tired, rusty choke spring hooked to a dirty carb that many of these old truck run. Thanks.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 11-30-2004, 12:44 AM   #5
jhow66
jhow66's Avatar
If you mean will it work ok then the answer is yes. If you mean how it works here's how--when engine is cold the coil spring contracts causing the choke butterfly to close by way of the rod between coil and choke lever. When engine is started exhaust gas crosses from one head to the other by the way of a passage (choke coil is setting on this passage) and out the other pipe causing the coil to expand and draw the choke open.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-30-2004, 08:08 AM   #6
JimKshortstep4x4
Smile
To add to jhow66's reply, we use the factory setup for the choke on several of our trucks and they do work. It seems that they need a lot of attention and adjustment to get them to work right. They work better if the engine is equipped with the thermactor setup and heat riser. (We don't have either one on any of our trucks).
Engine temperature is important so a 195 degree thermostat is desireable. It makes a difference if the exhaust crossover passage is clean and flows well.
The electric choke works better under a variety of conditions so that would be the one that I would recommend. A manual choke will work but they can have problems also.
Jim
Old 11-29-2004, 01:10 PM   #7
Peregrine
Peregrine's Avatar
That's what I have, a manual choke. It's cheap theft protection. I can keep mine running without it closed (it takes some work. My choke cable wasn't working right for the first 2 weeks of winter so I learned the hard way) but I doubt anyone who has never even heard of a manual choke will get my truck out of my driveway.
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 11-29-2004, 01:13 PM   #8
dubie
dubie's Avatar
I installed an electric choke on mine but I don't think it's working. Is it correct to run a wire from the choke to the UNFUSED spot on your fuse box?? I ahve mine hooked up this way, but it won't run the idle up when it's cold at all
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-29-2004, 01:20 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
Make sure it's not hooked up to a constant 12v source, otherwise the choke will always be open and not serving any purpose. Make sure it is only receiving 12v when the ignition is on.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-29-2004, 11:26 PM   #10
WB72
Before and After
WB72's Avatar
What is involved in the setup of an electric choke?
66,000 miles.
Alberta, CANADA
Old 11-30-2004, 12:32 AM   #11
jhow66
jhow66's Avatar
Try this setup-works good for me.
Old 12-01-2004, 12:11 AM   #12
jimfulco
Just don't forget to disengage the manual choke before you go driving all over the place.
jimfulco is offline   Reply With Quote
Old 12-01-2004, 12:26 AM   #13
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I have the same setup, it's called a divorced choke. When the engine's cold, the spring contracts(winds up) and closes the choke. When the engine starts to warm up, it expands(opens up) and the choke opens till the engine is at operating temp. and the choke should be open all the way. That's how mine is and I haven't had any problems with it.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-01-2004, 03:21 AM   #14
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I converted my q-jet to an electric choke & it rocks. I got the parts at the bone yard. I SEEM to remember that the late 70ies/very early 80ies have what u need. I will admit that it is a particularly fussy adjustment, but when its good is done like dinner. & ya, go to a fused ignition power source.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 12-01-2004, 03:49 AM   #15
71-longbed
Its Magically Delicious
71-longbed's Avatar
i have a divorced choke as well .. is it possible to attach a manual choke cable to my fast idle cam and remove the whole spring setup ..
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 12-01-2004, 08:48 AM   #16
1969K10
1969K10's Avatar
71-Longbed - I bought a "HELP" kit from one of the chain parts stores (A-zone or Advance - don't remember) and it comes with the choke cable, a bracket to mount the knob inside, and a clamp that attaches to the choke butterfly rod. I had to remove the bi-metallic spring on the side of the carb (Q-jet), and the housing the spring was it. Just a couple of screws...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
Old 12-01-2004, 03:07 PM   #17
71-longbed
71-longbed's Avatar
do you happen to know how long the choke cable has to be ??? do you have any pics ??? thanks a bunch
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
