Old 12-03-2004, 09:54 AM   #1
SprayPaint
Dually hub adapters or not?
Howdy,
Does anyone have any opinions about the dually hub adapters by Arrowcraft?
I am half way thru converting my '67 C20 to a dually setup. I was able to bolt up the rims to my eaton axle with minimal modifications, now I'd like to complete the look up front.
The adapters for the front are around $250 for the pair. Are there other options available?
And would there be issues of bearing stress or safety using these adapters?
Thanks!
SprayPaint is offline   Reply With Quote
Old 12-04-2004, 01:48 PM   #2
longhorn71
longhorn71's Avatar
i am wrecking a 67 daully if u need the drums and stuff for the conersion in the front.let me know and i will sell them cheap
longhorn71 is offline   Reply With Quote
Old 12-04-2004, 05:42 PM   #3
sdkid
Dodge truck ues a bolt on spacer on the front(94-? 99maybe) Possibly a salvage yard item. I do not know if they will work, but when I convert thats what I'll try first. Well if I get around to converting.
sdkid is offline   Reply With Quote
Old 12-04-2004, 07:31 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'm parting a 72 C30 dually, don't know how to get it to you but for $150 you can have the front end.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-04-2004, 10:46 PM   #5
SprayPaint
So what I am hearing is that C30 parts will fit on my front end?
Wow, that's a little more outside the box than what I'm used to... What parts are interchangeable? Forgive me for being a "lite weight" but you're going to have to spoon feed me a little on this one...
Old 12-04-2004, 11:14 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'll take a pic of it tomorrow. But the front ends of all the 2wds should be interchangeable to some degree. The 72 C30 had a 350.
Old 12-05-2004, 04:32 AM   #7
longhorn71
longhorn71's Avatar
ball joints and tie rod ends were the same on 3/4-1 ton from 67-70 and 71-72 control arm bushings and shafts[upper] were the same on 67-72 3/4-1 tons.lower ones were the same on 1/2-1 tons 67-72.pitman arms[off steering box]68-72 power steering are the same on 1/2-1 ton.69-72 manual boxs are the same1/2-1ton.67-72 1/2-1ton all have the same idler arm.67-70 3/4-1ton [with drum brakes] have the same spindles.71-72 [disc brakes] 3/4-1ton have the same spindles.I hope this helps
Old 12-05-2004, 06:49 AM   #8
SprayPaint
Wow, that's a lot of good info. So if all the parts on the front of my C20 are in good condition, is it just the drums from a C30 that I need? Thanks.
Old 12-05-2004, 09:13 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Should be just the drums to get you going....according to what I've been told
Lots of diesel guys use Arrowcraft adapters to turn 3/4 tons into duallies.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-05-2004, 11:46 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That is a lot of info!
Old 12-05-2004, 03:59 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
...and somewhat on the subject. Here is pic of a 3/4T Dana 60 converted to dually. Looks like it just involved spacers, big studs & nuts. Just a note, it is for sale: 3:54 with all new brakes, seals etc...$400.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
