Old 12-03-2004, 05:43 PM   #1
grnddwn
belly dragger
grnddwn's Avatar
Shop Truck
Just wanted to show you our new shop truck. Not me in pic
grnddwn is offline   Reply With Quote
Old 12-04-2004, 01:56 PM   #2
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
thats awesome
Bagd72Chevy is offline   Reply With Quote
Old 12-04-2004, 08:12 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Grnddwn,...cool pics! Any details on the front suspension? Also,... how about some current pics of your Blazer?!?
Keith
Convert to disc brakes.
Old 12-07-2004, 05:34 PM   #4
grnddwn
belly dragger
grnddwn's Avatar
No new blazer pics yet
Old 12-10-2004, 02:39 AM   #5
BK
BK Built
BK's Avatar
i agree, bad ass truck, more front suspension pics. also, am i the only one that looks like there isnt much room for travel in the trailing arm crossmember's driveshaft loop?
BK is offline   Reply With Quote
Old 12-10-2004, 09:16 AM   #6
smokekiki
Mike
smokekiki's Avatar
Looks like a pretty big hole to me.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-10-2004, 10:53 AM   #7
grnddwn
belly dragger
grnddwn's Avatar
Actually its has way more room than it needs. Truck has a two piece driveshaft.
Old 12-10-2004, 12:28 PM   #8
BK
BK Built
BK's Avatar
ok, that makes sense. I was just comparing it to stock loops and my loop on my ECE trailing arm crossmember. 2-piece... that explains it.
Old 12-10-2004, 03:01 PM   #9
PRUNEDA
'87
PRUNEDA's Avatar
PRUNEDA is offline   Reply With Quote
Old 12-14-2004, 07:54 PM   #10
grnddwn
belly dragger
grnddwn's Avatar
Hoods on
Old 12-14-2004, 08:06 PM   #11
luckydog
< Fav Place on Earth!
luckydog's Avatar
How bad is that notch gonna mess up your bed? I was thinking of raising my floor about 3 in., because I still want to be able to use it, and don't want a huge bridge in the way.
Horsepower is how FAST you hit the wall, torque is how HARD
luckydog is offline   Reply With Quote
Old 12-14-2004, 08:13 PM   #12
grnddwn
belly dragger
grnddwn's Avatar
I don't know yet I'll let you know as soon as the beds on. Maybe by the weekend.
Old 12-15-2004, 03:32 AM   #13
BK
BK Built
BK's Avatar
i was wondering how much of a Z that is and did you just put 3 joints and a heim in your steering shaft or what? im thinkin like 3" but not sure
Old 12-15-2004, 06:12 PM   #14
gunnersm8
ok, im thinking about this frame Z-ing, heres my questions... i understand the concept and how it works, what needs to be changed though? i dont see any geometry issues, is this correct? i guess what im asking is if i throw a 4-6 drop on my 69, but i want the front lower than that, can i put a 2-3 inch z in the front end and be done with it or does this entail other things, like susp geometry, clearance issues with the susp? i dont want to bag it, for no reason other than i dont want to, but i want that amount of drop.
gunnersm8 is offline   Reply With Quote
Old 12-16-2004, 09:27 AM   #15
smokekiki
Mike
smokekiki's Avatar
The reason for the bags is to get it that low with a z,and then lift it up a couple inches so You can drive it.With a 2.5" spindle 2" springs,and Z'n the frame,Yoo would be to low to drive around here without bags.
Old 12-15-2004, 06:12 PM   #16
lost wages
lost wages's Avatar
ok we need pics and details on the hood.
lost wages is offline   Reply With Quote
Old 12-15-2004, 06:45 PM   #17
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Does the hood tilting forward make the engine eazier to work on?
DroppedChoppedPanel
You have the new ECE crossmember? When does it become nessasary to install it? How low.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 12-18-2004, 11:58 PM   #18
XXL
Señor Member
XXL's Avatar
What he said.
XXL is offline   Reply With Quote
Old 12-15-2004, 06:56 PM   #19
grnddwn
belly dragger
grnddwn's Avatar
As soon as we finish the hood hinge I'll take some detailed pics for you guys. We are considering developing a kit for it. The hood springs are going to have to be heavier. The truck has a 2" Z and a 1.25 crossmember drop (which we do sell). The outside diameter on the tires is about 30" and the truck is hanging below the carts it is on. If you go much more than 2" you may have some radiator issues. We are just finishing up the back end I'll post some pics tomorrow.
Old 12-15-2004, 07:49 PM   #20
SCOTI
SCOTI's Avatar
Gets some pics of the steering shaft clearance solution when you have the camera out .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2004, 08:10 PM   #21
grnddwn
belly dragger
grnddwn's Avatar
Bumpers on
Old 12-15-2004, 08:40 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
Killer! So with all the drop combined your laying rockers. What hits the ground first now, the body or the frame? Give us as much detail as you can along the way.
Looks like the hood is going to need a bit of filler.... :p
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-15-2004, 10:02 PM   #23
BK
BK Built
BK's Avatar
hey, lets see some steering shaft pics... also, i got the ece auto tranny x-member, and i was thinking if i flipped it over, and turned the mount upside down, and sunk it into the crossmember a little bit, would that work for a 4" z???
bagged72blaz - I got it because it has the raised driveshaft loop(flat with the frame) so it wont drag, and it has holes to run 3" exhaust through. I plan to lay flat rocker or frame, and dont want things in my way.
Old 12-16-2004, 11:05 AM   #24
grnddwn
belly dragger
grnddwn's Avatar
We're notching the upper control arm for clearence works pretty good just need to do some re-enforcing I'll put up some pics when its done. The frame hits about a 32nd of an inch before the rocker. The hood looks alot worse than it really is we need to wash it.
Old 12-16-2004, 11:08 AM   #25
grnddwn
belly dragger
grnddwn's Avatar
We put the truck spring on the new hinges now it pops right open when you hit the latch.
