12-03-2004, 07:49 PM | #1 |
Help.... I don't know what motor is in my truck
I have always thought that the old 69 has a 307 in her, but i need parts, and wanted to verify before having some pimply faced kid at the parts store proving that i'm an idiot, so i thought i'd look it up. But come to find out, the number on the motor doesn't turn up in my book.
The number stamped on the right side head is: V1219TXD Can you help me?? Thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
12-03-2004, 08:03 PM | #2 |
member #16
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-03-2004, 09:16 PM | #3 |
Here is what I found:
TXD 1975 350 165 4 conv.cab I found it at http://www.chevy-camaro.com/chevy-ca...es.asp?group=6 Hope it helps....Larry
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1 RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall '05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD |
12-03-2004, 09:19 PM | #4 |
Unless you are buying internal engine parts.......it doesn't matter at all. Small block Chevys are the same as far as most things go.
12-04-2004, 10:19 AM | #5 | |
Active Member
Hmmm...according to that, my engine originally had a 4 barrel carb. Now I don't feel so bad about ripping out that "original" 2 barrel carb and manifold. |
12-03-2004, 09:32 PM | #6 |
So the cam and lifters i need are basic Small block chevy?
12-03-2004, 09:38 PM | #7 |
Yes, as long as you don't go radical. If a cam is radical in a 350, it will be even more radical in a 307.
12-03-2004, 09:40 PM | #8 |
Yup. The only difference you would ever notice might be in performance, but it wouldn't make much difference if the cam is near stock. The same cam would act a bit more radical in a smaller motor.
Meaning, if you put a "stock replacement" cam for a 350 in your engine...and it really is a 307, it will be a little more performance oriented. It would likely make more power and at a higher RPM. The closer the cam is to stock..the less affect this will have. I guess it would depend upon what you are looking for... |
12-04-2004, 01:38 AM | #9 |
My other Love
the number you need to be looking for is on the left side of the engine behind the cylinder head, usually hard to see and usually covered in lots of grime, the head could be off any motor
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
12-04-2004, 09:32 AM | #10 | |
Tim |
12-04-2004, 12:36 PM | #11 |
GM ONLY BABY!!!
Or try www.mortec.com
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
