Old 12-06-2004, 02:54 AM   #1
skokie
skokie's Avatar
Pvc Setups on a 68 with 327
Can anyone tell me what kind of pvc setup was used on a 68 1/2 ton with a 327?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-06-2004, 03:30 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
There is none on the 67 327 1 ton we have,just the canister in the lifter valley.I'm not sure if that is the stock setup,but there is no holes in the valve covers where it should be.
All the blowby comes out of the oil filler tube,and straight into the cab <choke cough>Stinks too
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-06-2004, 03:43 AM   #3
texnician01
texnician01's Avatar
Any motor that is pre 69 will have no provisions in the valve covers for a breather. They used the oil filler tube in the intake and a canister with road draft tube out the back. Some of them had an adapter in the place of the road draft tube that a vacuum line hooked up to like a pcv. All of the old blocks had a place in the back next to the dist for the road draft tube and the corresponding canister in the lifter valley. they also used an intake with oil filler hole. I ran into this problem with my 327 cause I used a newer block with old valve covers and intake. I have a vent through the filler tube but no way to pull air through the block. we drilled and tapped the intake for a chrysler pcv valve but it pulls too much oil vapor from the lifter valley and burns it. the thing looks like it has bad rings or valve guides cause it leaves a blue cloud. We are in the process of fabricating a canister type setup to slow down the air and get the oil droplets out before sending it back into the engine.
Hope that gives you some info.
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 12-06-2004, 03:48 AM   #4
68CST327
My 68 327, completely stock, has the PCV setup on it. One hose going from drivers side valve cover going to base of carb, passenger side valve cover has PCV valve in it... or something like that. I can't remember too well at this hour.
68CST327 is offline   Reply With Quote
Old 12-06-2004, 04:11 AM   #5
texnician01
ok maybe it is 67. It's the ones that use solid valve covers if you have a pcv in the covers then you are set.
nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 12-06-2004, 04:14 AM   #6
68CST327
It's one of those years in there. All I know is that it signaled the beginning of the emissions controlled, power-choking era
Old 12-06-2004, 09:42 AM   #7
toms68cst
toms68cst's Avatar
My 68 327 has a stock PCV valve too. I don't remember how everything's piped up but I can snap some more pictures for you if you want skokie.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 12-06-2004, 11:09 AM   #8
bagged74
its just $$$$$
bagged74's Avatar
my 68 with a 307 has a pcv valve in the valve cover also.
bagged74 is offline   Reply With Quote
Old 12-06-2004, 07:13 PM   #9
skokie
skokie's Avatar
Toms68cst pics would be good.
68 build thread
Old 12-06-2004, 03:01 AM   #10
skokie
skokie's Avatar
Typo. PCV is correct
68 build thread
