12-16-2004, 12:33 AM | #1 |
1406 edelbrock problems
I have a fairly new 1406 on a Chev 350. I have developed a flat spot on acceleration. Right after idle it wants to bog. I took it apart and everything seems to be ok. Any ideas? Also, when I first press on the accelerator in the morning to set the chock I feel a fairly strong resistance than it snaps free and allows my foot to go to the floor, what could cause that? Thanks
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
12-16-2004, 02:17 AM | #2 |
Your UncleBen
Hey,
Fuel pressure regulator set at 4.5-5 psi is what you need. Edelbrock should start including them with carbs when they sell them. lata CHRIS
68 C10 shortbed -- Street/Strip |
12-16-2004, 12:50 PM | #3 |
Thats the Hillbilly way
Ron; Did the carb work OK B4 this , if so I would check the timing , also make sure the linkage isn't binding,vacuum advance .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 12-16-2004 at 02:16 PM. |
12-16-2004, 02:25 PM | #4 |
i have a 650cfm,i think a 1406 is a 600cfm?, edelbrock on a 350 and mine does the same thing when i try to slam it. it works fine under normal acceleration but when i hit it it will sometimes "bog down" it didnt do this when i first installed it a year ago, and i have a timing light and have checked the timing several times. at idle and hot engine temp i have it set at 6 degrees btdc.
sweetlandlong68, where did you install your regulator and where did you get it? Also, how did you know to set it at 4.5-5psi??
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-16-2004, 07:41 PM | #5 | |
Your UncleBen
Setting it at 4.5-5psi was learned by talking to Edelbrock and just some trial and error. lata CHRIS
