12-16-2004, 09:48 PM | #1 |
Power Steering Conversion Question
I'm looking to do a power steering conversion on my 1971 Chevy. I have found a complete setup (gearbox, mounts, and pump) from a 1979 Chevy. Will this bolt directly up to my truck or should I hold out for a setup from an earlier truck?
Thanks for the help, Steven
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 |
12-16-2004, 09:56 PM | #2 |
member #16
The later one will have brackets and pulleys for long water pump. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-16-2004, 10:00 PM | #3 |
Got Light Emitting Diode?
the box will work fine, but as posted above it is for a long water pump
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
12-16-2004, 10:07 PM | #4 |
Could I just go to a long water pump or would I need to get a different steering pump?
12-18-2004, 01:30 AM | #5 | |
12-16-2004, 10:51 PM | #6 |
To go to long water pump you would also have to change alt/AC brackets, crank pulley. Better to just get different steering pump bracket the pump should bolt up fine.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
12-17-2004, 03:04 PM | #7 |
So I would just need a set of brakets for the pump and short water pump.
12-17-2004, 05:28 PM | #8 |
Yes, and yours should already have a short water pump (unless someone changed it). Difference between short and long pump:http://67-72chevytrucks.com/vboard/s....php3?t=109160
12-18-2004, 02:28 AM | #9 |
senior member
look for a bracket out of a late 70's early 80's van it worked fine for me
69 GMC bagged |
12-18-2004, 08:42 AM | #10 |
Thanks for the help everyone. This has really helped me out and saved me some money now that I know what parts I'm looking for.
Steven
