12-17-2004, 11:26 PM | #1 |
69 chevy LWB (IN BC) 383/th400
Ok I hate to sell this Its my unfinished project But I need something I can drive now and drive without dieing at the gas pump
The truck has a 383 stroker with 041 heads (same as camel bump) Performer Rpm manifold Carter Competion Afb Hei Dist with Accel Hi output cap I think it has a Rv cam in it but I havent checked yet Motor has about 40 000 on it Runs perfectly It pulled out has Manifold carb and oil pan/ timing cover taken off heads are still on Also has Th400 rebuilt 7000 k ago has Tci HD converter put on when rebuilt Stage 2 shift kit Truck itself needs Cab mounts corners front passanger floor patch One fender needs a patch the other could be patched but would be better off replaced Grill is pretty damn good I also have a front clip from a 76 to convert over to front discs Has dunlop Something tires they have 80 percent or so left Bed has white oak no rotting (had a canopy on it) but it could use new finish on it Bed has pretty much no rust and no dents Truck also has headers and dual exaust I also have another set and a 1 gallon of oxide primer and 2 gallons of gloss black paint and 250 pounds of sand to strip the frame This truck has alot invested in it And I hate to give up on at thsi point but It really isnt practical for me to have right now It also has tons of other stuff to go with it 4500 or trade for a nice day driver Im pretty firm on that And I am i no no rush If I cant get about that then I will keep it and buy another car It is insured as a 72 I think Someone swapped on this cab since it has 6 lug and 4 wheel drums
Wont you ride my white horse Its symbolic of course |
