Old 12-20-2004, 02:07 PM   #1
booth
Active Member
booth's Avatar
Vin Trouble
Well I picked up what I think to be a '68 GMC LWB from Fleetside72 this weekend. I am having trouble deciphering the VIN- CS2590D PC3227B. Can anyone out there give me a hand? I would post a pic of the vin plate but I think the pics I have are too large.
Thanks,
Paul
booth is offline   Reply With Quote
Old 12-20-2004, 02:17 PM   #2
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
re
Go here:
http://67-72chevytrucks.com/Chevyear.html
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 12-20-2004, 02:21 PM   #3
booth
Active Member
booth's Avatar
Thanks,
I went there but the numbers I have don't jive with whats on that page.
Old 12-20-2004, 02:26 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
GMC VIN's are not sequenced the same as Chevy. Gohere
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-20-2004, 02:48 PM   #5
booth
Active Member
booth's Avatar
Alright that clears up some of it. CS259OD PC3227B= 2 wheel drive, v6, 3/4 ton, Wide Side, Pontiac, 1967. The 59 is the only part that doesn't work out.
Thanks guys,
Paul
Old 12-20-2004, 03:23 PM   #6
1971LT1SWBPOSI373
re
Where you at in MN?
Drinks Miller MGD
Old 12-20-2004, 06:29 PM   #7
Rod
CS2590D PC3227B
C= Conventional
S = six cylinder
2= 3/4 ton
59= a 54 inch dimension from cab to rear axle....they just did it like that.
0D= wide side box
P=Pontiac asembly plant
C= 1967
Rest is sequence number
Are there marker lights on the side of this truck?
I had one truck I saw have the B at the end also.
From what I can figure..its a left over type way that GMC trucks produced in the United States were given a GVW rating...typically B meant 3/4 ton.
In older 62-66 trucks thats the way GVW rating were done. So that's what leads me to think that way.
It works in this case.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-22-2004, 01:33 AM   #8
roger0080
Since the pics are too big to post? could you e-mail be a picture of your glove box option sticker and the vin plate to roger0080@netscape.net? I'ld like to see this.
I have a picture of an option sticker with a "B" on the end of the VIN, but of course, I cannot readily find it. Dang. Thought I was seeing things when I first saw that (wasn't perfectly clear photo).
Rod, are you saying that for this GMC VIN that they stuck the cab-to-axle in the VIN? That would have to be the weirdest I've seen on here. Wonder what the MODEL= looks like then.
The 2 and B in this case would be redundant info in the VIN.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 12-22-2004, 08:51 AM   #9
Rod
Yep the 2 and B are redundant in my opinion also.
Let give a stab at a model number and see what happens..
How's this one look
CS25934
or
CS2590D
one other possible way is
C9S25934
But I haven't seen too many that last way...but its a GMC. So?
I'm guessing the first one.
I figure thats whats there.
I'm guessing that the year is not in this ones model number code. Lets hear about it.
Old 12-22-2004, 08:58 AM   #10
Blue Beard
Blue Beard's Avatar
If you'd like to post the pics...email them to me and I will resize and post them for you.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 12-22-2004, 10:04 AM   #11
booth
Active Member
booth's Avatar
Unfortunatly the glove box sticker is gone. Was there such a thing as a heavy 3/4 ton? This truck looks like it has a Dana 60 with some very beafy leaf springs. This truck also has a '70 chevy front clip and hood. Blue Beard whats your email? I'll send you some pics.
Thanks,
Paul
Old 12-22-2004, 08:28 PM   #12
roger0080
Rod, I have a picture of a 1967 Oshawa funky VIN, funky Model:
VIN Number: C9S1471<can;t read>
MODEL# C9S10934
Still look'n for the B vin...
Why is GMC so all over the board with this stuff while its counter-part Chevrolet is more consistent through those years? sigh.
Old 12-22-2004, 08:56 PM   #13
Rod
Thats a 67 GMC..it was fairly common for GMC trucks built in Canada to have that 9 after the First C. It designated that the truck was built in Canada. You can see it was buit in Canada by the number 1 in the assembly plant position...Oshawa Plant in Canada....
C9S1471 < Thats last number 1 being the assembly plant position.
C= Conventional
9= GMC Canadian Built
S= Six cyl
1 = 1/2 ton
4= fleetside box
7= 1967
1= Oshawa assembly plant.
Its sort of like the 72 vins where a second letter C meant Chev while a second letter of T meant GMC
CCE142
CTE142
start like those above in 72 only for 1/2 ton 2wd.
Your model number MODEL# C9S10934
C= conventional cab
9= GMC Canada
1= 1/2 ton
09= 54 inch dimension from cab to rear axle.....you'll notice GMC and Chev used different numbers to represet 54 inches,..while GMC used code 59...chev model number used code 09
34= fleetside
Works out all pretty simple once you see them all a few dozen times.
That last letter dosent show up often...but I have seen it.. if it were in vin in your case it would have been a letter A to represent 1/2 ton GVW at the end of the vin not the model#.
so B = 3/4 and C = 1 ton and so on upward as the GVW's climb.
Old 02-08-2005, 12:40 AM   #14
roger0080
[For Rod]
Here is a listing on e-bay that has an "A" at the end of the VIN.
No picture but the seller states the VIN as: CM159ODPC5644A
Here is the link:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4526048127
Old 02-08-2005, 01:01 AM   #15
Rod
CM159ODPC5644A I see a pic of the truck..and its a 67 GMC...no pic of vin plate but anyway
C=- conventional cab
M= V6
1= 1/2 ton
59= cab to rear axle is 54 inches
OD= wideside
P = pontiac assembly plant
C=1967
5644= sequence number
A= GVW range of 1/2ton
see the pattern of the GVW range at the end of the vins..above trucks vin is a 1/2 ton hence A..
way the threads up the truck had a B at end and it was 3/4 ton..hence B is 3/4 ton.
