rear gears?
I picked up a nice 87 stepside silverado 2wd last fall. It's got the 305 tbi with 700r4. It's not a powerhouse, but then again it gets great gas mileage. Right now it's covered up under 2 feet of snow.
Anyone know of an easy way of determining what the rear axle ratio is without opening up the rear? I've heard of rotating the driveline 1 turn and counting the revs of the rear wheels. Any other suggestions?
bw 70 chev short/fleet:son's hotrod w/tickets to prove it 69 gmc short/step: project in pieces 87 chev short/step: still thinking about 2000 gmc xcab/step: daily driver |
If you have a tach u can use rpm, speed, and tire height to determine the axle ratio.
Here is a link with several calculators that can help u. www.csgnetwork.com/automotiveconverters.html |
i'd almost bet its a 2.73
Insert Witty Text Here
My '86 lists the rear end ratio in the glovebox. Yours might as well. Mine is a 3.08.
Slonaker |
Stepsides RULE
yeah check the dealer option sticker in the glove box or the one in the doorjam.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
I took my serial number to the local GM dealer and my buddy printed me out a build sheet.
Mine's a 3.08. Betting yours is too.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
mine was a 2.73
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
any luck?
No luck yet, can't check the glove box idea until the damn snow stops blowing. I'm guessing it's 3.08, although 2.73 has been suggested. The last article I read said 3.08 was the tallest available though. Were 2.73 available?
ROCKET POWER!
Even a 2.56 ratio was available. What insane string of thoughts transpired that idea we'll never know. Those gear sets serve no imaginable purpose and after being retired from their truck duty are most effective as paper weights.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
Stepsides RULE
hey hey hey!! I'm glad i got nice and long 2.56, being as with a non-od tranny, it helps gas mileage.
7000 #'s of american IRON
look on the axle- i heard on some axles there'll be a label riveted to the axle somewhere- either the diff cover or axleshafts, and it'll have the ratio on it.
usually the axle tag is gone,but if it survived,it will be on one of the upper cover bolts,you can't miss it if it's there.Honestly,if you want to know for sure,spend a few bucks on a gasket and a couple quarts of gear lube.The ratio is stamped on the ring gear,usually the # of teeth on each gear.You could probably use some fresh gear lube anyways.
