Old 12-22-2004, 10:15 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
What kind of transmission do I have
I don't speak fluent manual transmission in old GM vehicles. My 72 1 ton dually has a big, clunky, 4 speed in it.
What transmission would it be?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-22-2004, 10:22 PM   #2
dwaite72lnghrn
I'd think it would be the 465 reverse down and to the right, Granny low up to the left!
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 12-22-2004, 10:56 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I stole this pic off ebay. This is a SM465. Does it look like this?, because these are pretty common from 1968 to mid 80's trucks.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-22-2004, 11:09 PM   #4
3 on the tree
Could be a NP 435 also. I will have a round or square tag with NP 435 stamped on it.
3 on the tree is offline   Reply With Quote
Old 12-22-2004, 11:52 PM   #5
70c10
67-72 Addict!
70c10's Avatar
3 on the tree could be right also. This link shows the pan differences, dimensions, top cover (aluminum or iron), PTO port locations,etc. This should make it easy for you:http://www.eastcoastk5.com/Tranny%20Tech.htm#465
Jim
Old 12-23-2004, 01:08 AM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I pulled a 4 speed out of a '72 GMC 1 ton and found out it's a 4 speed muncie. I'll get a pic out of a service manual later.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-23-2004, 01:55 AM   #7
687980chevy
687980chevy's Avatar
Muncie made the sm465 for GM. 70c10's picture is also the 4wd version you can see the flange & bottom mount for the T-case. All 3 of my trucks are sm465's some are sloppier shifting than others.
68 K-10,79 K-10,80 C-30
57 chevy convertible
79 Z28
687980chevy is offline   Reply With Quote
Old 12-23-2004, 12:44 PM   #8
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Tx,
Novak's site for 4x4's has a good picture of various manual transmissions for comparison purposes. Each picture links to a more detailed description of each tranny.
This is often caused by a break in the hardened tip of the shift lever. This is the part just below the collar that holds the lever in the tranny cover. The lever is joined to a hardened steel cap that will break, but doesn't come apart, so it just gets sloppy. If you can wiggle the hardened tip, it's broken. GM still has the new ones. They even come in chrome, but they're pricey.
It makes a big difference in the slop.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 12-23-2004, 04:34 AM   #9
1969 GMC
1969 GMC's Avatar
if it has an aluminum top cover, its the NP435. However it came in close and wide ratio versions, which would be indicated on the SPID label. if it has a cast iron top cover and is original, its the 465. it should have two pto ports and reverse to the pass. side and down.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-23-2004, 04:45 AM   #10
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
in my 68 the build sheet said M20 which i assume is the same as a sm420, pics not quite as clean as the one above
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-23-2004, 09:43 AM   #11
arkracing
Weekend Warrior
are they worth anything? or just good for weight in scrap? i had one in my truck with the cast iron top and PTO ports on both sides (for 4x4)??? it looks like the one in the last pics posted...greasy + red. mine is just greasy
i don't plan on using it
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-23-2004, 02:57 PM   #12
1969 GMC
1969 GMC's Avatar
nope that is a 465, M20 is GM's generic code for a 4 speed truck transmission iirc. so they used the same code for the 420 or the 465. yours has 2 pto ports so its the 465.
1969 GMC K2500
1996 Honda Accord
Old 12-23-2004, 03:35 PM   #13
68w/sbc406
68w/sbc406's Avatar
well i guess thats what happens when you assume, thanks for letting me know what i had. it went to the dump a while ago
Old 12-23-2004, 10:04 AM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The SM 465 has pto ports on both sides. The NP435 has a pto port on the pass side and the SM420 has a pto port on the driver side.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-23-2004, 01:31 PM   #15
Cethern
What was I thinking??
Cethern's Avatar
My vote would be a sm420 Reverse on that would be to the lower left.. The case has a hump on the passenger side.
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 12-23-2004, 05:46 PM   #16
Cethern
Cethern's Avatar
Yes thats for the PTO
Old 12-23-2004, 07:20 PM   #17
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
And here is a PTO:
