Old 12-27-2004, 09:50 PM   #1
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Anybody using this cool setup???
3" x 16" Stainless Steel Overflow Tank. Pretty sweet for around $35-40.......Opinions????
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 12-27-2004, 09:55 PM   #2
Vince Putt
Hippy
I've used them in the past and planning on using it on the next project. sure beats a plastic bottle. But doesn't have the class of a Yuengling can
Vince Putt is offline   Reply With Quote
Old 12-27-2004, 09:57 PM   #3
Deuce
Deuce's Avatar
Looks like it should work well. Who makes it??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 12-27-2004, 10:03 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Look on Ebay. They are even cheaper there. I have seen them for less than $20.00...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-27-2004, 10:49 PM   #5
Sweet72
Sweet72's Avatar
Looks real slick.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-27-2004, 11:00 PM   #6
CHEVYE
my gas saver
CHEVYE's Avatar
i used one on my chevy 2. i took it off before i sold it and plan to use it on my truck (in whatever millenium it gets done)
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 12-27-2004, 11:17 PM   #7
Mudder
Mudder's Avatar
I have been using one of those for several years now. Look at the left side of the grille.
Mudder is offline   Reply With Quote
Old 12-27-2004, 11:18 PM   #8
Mudder
Mudder's Avatar
I have thought of painting it black!!!!!!!!
Old 12-27-2004, 11:21 PM   #9
Bamm
Bamm's Avatar
You can get the smaller ones pretty cheap on there ($20 or so) This one is the biggest one i've seen (3" x 16"). I am looking at this one from bigbauto @ $34.99 +shipping "buy it now". If you see this size cheaper, let me know. I would love to see a pic of one of these installed on our trucks. Thanks, ......Jerry
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 12-27-2004, 11:22 PM   #10
Bamm
Bamm's Avatar
Sorry Mudder, posted before I read your reply. Have you got an engine bay shot that shows your setup? Thanks, .....Jerry
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 12-27-2004, 11:48 PM   #11
Mudder
Mudder's Avatar
Thought I did but cant find it. It's just mounted to the side of the radiator opening with a couple of holes to be drilled for the hoses.
Old 12-28-2004, 12:23 AM   #12
Bamm
Bamm's Avatar
Hey Mudder- instead of painting it black, why don't you just get some black tape/graphic material and cover just the stainless that shows through the grill area. You would still have that cool stainless look under the hood without it showing through the grill. Just a thought........Jerry
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 12-28-2004, 12:26 AM   #13
Randy70C-10
Randy70C-10's Avatar
Hmmmmm, overflow tank looks familier.
Randy70C-10 is offline   Reply With Quote
Old 12-28-2004, 12:30 AM   #14
Bamm
Bamm's Avatar
Evenin' Randy, you up watching the game too or just surfin'?......Jerry
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 12-28-2004, 12:39 AM   #15
muddpile
muddpile's Avatar
Wow! That looks a lot better than my red antifreeze jug with a hose duct taped to the top of it!
muddpile is offline   Reply With Quote
Old 12-28-2004, 01:18 AM   #16
kingsolver72
10/30/19
kingsolver72's Avatar
Go Rams.
kingsolver72 is offline   Reply With Quote
Old 12-28-2004, 09:10 AM   #17
70c10
67-72 Addict!
70c10's Avatar
When I get mine,I plan to mount it on the side of the center grille brace and paint it black. My buddy just had one made just like that.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-28-2004, 09:56 AM   #18
Randy70C-10
I was just surfin......now I'm surfin again.
Old 12-28-2004, 10:29 AM   #19
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That is a sweet looking set-up...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-28-2004, 11:53 AM   #20
WestCoaster
Junior Member
WestCoaster's Avatar
I put one on the truck, functional and looks good. The unit I bought had a smooth 3/16x1" SS tube on the bottom for the overflow hose. I did not like size or lack of hose barbs, so I machined a SS nut with a small flange, drilled the bottom of the tank to match the flange, tapped the nut to 1/4 NPT and tig welded it to the bottom and then inserted 1/4x1/4 hose barb to attach the overflow hose.
1970 GMC 2500
1994 S10 SuperSport
2000 16' Customweld FishN Boat
WestCoaster is offline   Reply With Quote
Old 12-28-2004, 11:55 AM   #21
ChevyDude
I have one of those for my 71'. Bought it on Ebay from: http://cgi.ebay.com/ebaymotors/ws/eB...category=46096
You can go to their EBAY store and look for Overflow Tanks....they have lots of sizes.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 12-28-2004, 12:11 PM   #22
rickspickuppart
tank
I highly recomend them we use them on most everything we build anymore- hell I even used one on my daughters gocart for a fuel cell (motor was gravity fed and it did require a few mods to the tank - and it would give about 20-30 minutes of run time). The only thing I was ever concerned with when I used as a fuel tank I was removing and replacing the cap pretty often to put fuel in it and since the cap made out of polished aluminum and the tank is stainless and it would be easy to tear the threads up, I never had a problem but it was always on my mind when I was doing it.
Shawn
rickspickuppart is offline   Reply With Quote
Old 12-28-2004, 01:11 PM   #23
Wootdog
Wootdog's Avatar
Got something similar for the remote pwr steering.
Resevoir. Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 12-28-2004, 02:45 PM   #24
Mudder
Mudder's Avatar
Just came back from taking pics and they suck. It was sort of dark and I cant hold th ecamera still.
Old 12-28-2004, 03:10 PM   #25
Bamm
Bamm's Avatar
Chevydude, thats the guy i'm getting mine from just trying to figure out which size is the best for our trucks. What size is your's?
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
