Old 12-29-2004, 01:23 PM   #1
kevin from oc
kevin from oc's Avatar
stock radio install
Help i have the stock radio with 2 jambnuts 2 control knobs and 2 selector knobs the radio shafts dont stick out far enough to put the nuts on am i missing a peice?? photo anyone?
kevin from oc is offline   Reply With Quote
Old 12-29-2004, 01:26 PM   #2
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
the stock radio also had two cups to help hold it in place.....that shouldnt keep it from not sticking out the hole.
mblackburnjr is offline   Reply With Quote
Old 12-29-2004, 01:28 PM   #3
kevin from oc
i'm sorry the shaft sticks out the hole but the threads are not out far enough to get a nut started are the cups you have threaded?.
Old 12-29-2004, 02:24 PM   #4
Putter
More Cowbell....
Putter's Avatar
The cups you are looking for are recessed back into the dash, which will provide plenty threads for the jam nuts to hold onto. I will try to locate a picture for you....or if someone else has a photo of the cups....then it will as clear as day...
ERIC
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-29-2004, 02:30 PM   #5
71swb4x4
71swb4x4's Avatar
http://67-72chevytrucks.com/vboard/s...ght=radio+nuts
Here is a pic that longhornman posted.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-29-2004, 02:40 PM   #6
Putter
More Cowbell....
Putter's Avatar
Bam. Thanks 71swb4X4.....that is the photo....just install those cups in the holes so they recess toward the engine, and the nuts will go right on.
Old 12-29-2004, 03:30 PM   #7
kevin from oc
Thanks for the help
thanks you guys are the best!
Old 12-29-2004, 04:51 PM   #8
mblackburnjr
on a shorter note...you can get away with only one cup,if the radio is fastened at the rear to the dash..I know,cause when pulling my radio from a junker,i dropped one through the floor and never did find it.....
