Old 12-30-2004, 02:31 AM   #1
hilljack
Does your blower motor always blow?
In my 74 when I have the fan in the low position and the selector switch in the off position, I can still hear my fan blowing at low speed. I was just wondering if maybe the selector switch is what actually turns the fan off and possibly not functioning or is this normal?
Thanks!
hilljack is offline   Reply With Quote
Old 12-30-2004, 04:21 AM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
Mine does that too. I dunno if it completely turns off or not. I just dont worry about it. :p
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-30-2004, 05:22 AM   #3
TIMSPEED
TIMSPEED's Avatar
Yep, that's right. When my key is in the ACC position, the blower motor runs...never understood why, but I guess they did.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-30-2004, 07:46 AM   #4
Blue Beard
Blue Beard's Avatar
My guess would be the switch is bad, have a 81 that does that and if I move the switch it shuts off.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 12-30-2004, 08:37 AM   #5
76bonanza
76bonanza's Avatar
Everyone I have ever owned has done it it is the way they are made. I wired in a toggle switch to shut it off in the summer.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-30-2004, 09:29 AM   #6
Mike76251
My '84 fan runs all the time unless the selector is in the off position.......then it shuts off.
I shut it off all the time 'cause it saves alot of dusting inside should I have to go through a dust cloud or something.
Mike76251 is offline   Reply With Quote
Old 12-30-2004, 12:21 PM   #7
KShortell
KShortell's Avatar
Thanks!
On earlier and non-A/C trucks, this is normal. By the mid-80s, A/C-equipped trucks like mine have the fan actually off with the selector in the "Off" position.
Semper Paratus
KShortell is offline   Reply With Quote
Old 12-30-2004, 01:20 PM   #8
cliffsta
Stepsides RULE
cliffsta's Avatar
I don't get why the fan speed switch, when all the way down, still blows. Then low mark is blows Mid power, the hi mark it blows full on hard, then all the way up it doesn't blow....
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 12-30-2004, 03:41 PM   #9
76sierraclassic
As stated above, it's supposed to blow all the time. It's a "safety" thing allowing "fresh" air into the cab all the time even while just idling. However, it's not supposed to work like cliffsta's does....
Mike
76sierraclassic is offline   Reply With Quote
Old 12-30-2004, 06:01 PM   #10
Slonaker
Insert Witty Text Here
Slonaker's Avatar
...the hi mark it blows full on hard, then all the way up it doesn't blow....
If yopur highest position does not blow, check the plug on the wiring harness above one of the valve covers. The high position has its own power lead, and they tend to burn up the connector over the valve cover over time.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-31-2004, 12:52 AM   #11
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
. . . the hi mark it blows full on hard, then all the way up it doesn't blow....
As stated before, check the connection above the passenger valve cover area, and also, the high (all the way up/ Max cool ) use a relay located on the evaporator box in the engine compartment. Check the relay too.
NeCrOmAnCeR is offline   Reply With Quote
Old 12-30-2004, 03:37 PM   #12
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
As stated above, if you don't have AC, it always blows, this was part of the Flow-through power ventilation system.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-30-2004, 06:18 PM   #13
cliffsta
Stepsides RULE
cliffsta's Avatar
lol oy my truck. I wouldn't be lying when i say its a one-off.....
Ill add it to the dumb things i like about my truck, like how its a Custum Deluxe but its spec'd with Cheyenne or Bonanaza options...
Old 12-30-2004, 09:40 PM   #14
hilljack
Cool thanks guys, my truck is AC but probably just the same unless fan power goes through the selector switch on a 74 with AC????? Now on to the next problem, see ya in my next posts
Old 12-30-2004, 11:12 PM   #15
1976K5CHALET
1976K5CHALET's Avatar
On my 79 i got a hvac control head out of a mid to late 80's burb with the pigtails...there was one wire difference i remember right as it's been two years or better...but after i installed the newer panel and wired it in the fan stays off in off.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 12-31-2004, 12:14 PM   #16
Mike76251
The real strange thing is WHY it is a safety issue for the fan to blow all the time.
It's like Chevy expected the exhaust to leak forever or something!
