Need Some Advice
I pulled the sway bar off of my parts truck and was planning on putting it on my restore. I realized that the fame I took it off of had rivets drilled out of it in the front crossmember so the sway bar brakets could bolt up. Should I do the same thing on my restore frame or not add the sway bar? What difference will I notice with the sway bar?
Brian Thompson 99 2500 Silverado 6.0 05 Suburban (Wife's) 67 Mustang (Wife's) |
I also have some motor mounts on my parts truck that do not look like they are standard. They bolt to the frame but not the crossmember. I would think they would bolt to both.
Watch out for your cornhole !
![]() Join Date: Jun 2003
There's a good article in the FAQ section all about swaybars and swaybar installation. Lots of pictures.
The engine mounts should bolt to the truck with 3 bolts each. To the frame with 2 bolts and the crossmember with 1 bolt each.
Thanks for the reply. The mounts are only bolted to the frame and not the crossmember. I will try and get some pics. They may be from another year. Thought they should have the two bolts in the frame and one in the crossmember.
There's 2 sets of holes in the frame and crossmember. See if they fit the other set.
:d
To answer your other question, (swaybar) go ahead and pull those rivets out of your frame. Just be sure to put a bolt back in if you don't install your swaybar brackets right away.
