Old 01-05-2005, 05:03 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
replacing wheel cylinder
Do I have to take the drum apart to replace the rear wheel cylinders? I went outside yesterday to take a quick look and there is two bolts on each side of the bleeder screw, if those are unscrewed will it slide out the back?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 01-05-2005, 05:27 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes, because it wont come thru the backing plate
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-05-2005, 06:18 PM   #3
gr8scott51
gr8scott51's Avatar
The wheel cylinder is an integral part of the braking system. Compression of the brake fluid via the brake pedal increases the pressure within the wheel cylinder, thus expanding the brake shoe diameter causing friction against the drum.
Yes you have to remove the drum and disassemble the brake components.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 01-05-2005, 06:21 PM   #4
skokie
skokie's Avatar
Seeing how its stopped raining I will be changing the wheel cylinders on my truck to.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
