Old 01-06-2005, 12:25 AM   #1
k9ulan
Headlight problem
Anyone have any Idea why my headlights quit working..? All other lights work fine..and i jumped the dimmer switch..wont work on either side..bright or dim 1970 c/10 beater.
k9ulan is offline   Reply With Quote
Old 01-06-2005, 12:42 AM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Get a test light and turn the headlight switch on and see if you're getting power to the headlight wiring connectors. If not, check the fuse on the fuse panel. If those aren't the problem then you're switch might be bad. Do your instrument panel lights come on?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 01-06-2005, 01:29 AM   #3
k9ulan
yep..panel lights come on..bright indicater too..
Old 01-08-2005, 05:35 PM   #4
k9ulan
anybody gat a lighting diagram / schematic they can point me too..
Old 01-08-2005, 05:39 PM   #5
jhow66
jhow66's Avatar
Check to see if you are getting power to dimmer.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-08-2005, 05:46 PM   #6
k9ulan
bright indicater light on dash comes on and off accordingly whren dimmer switch is pushed
Old 01-08-2005, 07:06 PM   #7
jef5150
Inline 69
jef5150's Avatar
lights
heres a link http://www.geocities.com/chevroletc1070/wiringdias.html jeff
jef5150 is offline   Reply With Quote
Old 01-09-2005, 11:37 PM   #8
k9ulan
Originally Posted by jef5150
thats is very helpful..thanks
Old 01-08-2005, 07:08 PM   #9
Don R. Dodson
Sounds like your bulkhead connector has a mind of it's own. The dimmer switch gets the headlight power from the headlight switch on a light blue wire. From the dimmer switch there are two wires that goes to the bulkhead connector. The light green wire is the bright light wire and that wire also goes back to the intrument guage cluster to light the bright light indicator. so you have power going to one side of the bulkhead connector. The other wire is labeled 1st, so it's anybody's guess what color that wire is, but you get the drift. Both the light green wire and the other wire 1st goes to the headlamp sockets. Very doubtful that both headlamp sockets have lost a ground on both plugs so that is on the back burner to check for grounds. Probe the engine side of the bulkhead connector with a test light going to the light green wire with the bright light indicator on. You should have 12 volts on the engine compartment side. YOu should be able to take it from that point. Have fun under there with them spiders.
~ Don ~
Don R. Dodson is offline   Reply With Quote
Old 01-09-2005, 11:35 PM   #10
k9ulan
Ok. i went and got a new dimmer switch/headlight switch and 2 newe headlights...changed rthem all..works..so out of sheer curiousity..i changed each old peice back in 1 at a time..an it still worked..only thing i left in new was the headlights...go figure..2 completely bad headlights..?..seems so.
