01-06-2005, 05:47 PM | #1 |
Hose off of Master Cylinder
Still trying to hook up all the misc items....Here is the next one.
The hose coming off of the front of the master cylinder...Where should it connect? Thanks for the help, Rick |
01-06-2005, 07:34 PM | #2 |
Do you mean the brake booster? If so it goes to the manifold.
01-06-2005, 08:15 PM | #3 |
Yes, off the break booster.
I'm assuming this is for vacuum off of the manifold....Is there any special values/adapters required for this connection? Is it just a simple threaded fitting with a slip end for the hose? Sounds like a silly question, but without any examples available, I'd just assume not screw things up. Thanks, Rick |
01-06-2005, 08:21 PM | #4 |
It goes on the manifold behind the carb. There should be a "t" fitting on the manifold.
On my 69 3/4 ton the rubber hose from the booster connects to a hard line then it screws on to the T fitting. Might be different for other years. |
01-06-2005, 08:21 PM | #5 |
go cyclones
I have one that runs into the a tee behind my carb. One if for the brake booster and one is for the transmision. I do need the a new rubber grommet for the brake booster if anyone can direct me where to find one.
