Old 01-08-2005, 02:04 AM   #1
rustyold72
rustyold72's Avatar
Crack in frame
So I was taking the front end off the frame, and where the shock bolts to the frame (drivers side), there is a crack (2 inch long) I know it's possible to weld up a crack, but would it be safe, or am I risking the frame breaking?
Should I get rid of it or have it welded?
Just when I thought the frame wasn't in as bad shape as I had thought............................... this pops up
Just realized that if I have to dump the frame, the only pieces left of the original truck will be the front suspension, one door, and a fender
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 01-08-2005, 04:07 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Weld it and forget about it...no problem. The frames on these trucks are really low alloy steel and you can weld them all day long with no problems. If you cannot do it yourself I am sure one of the board members can help you out. Post a picture of the crack but I am sure you can probably drive to wherever you need to get it welded.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-08-2005, 04:23 AM   #3
Super Duck
Chevy Nuttttt
Super Duck's Avatar
if I were home i would take care of it in a minute but I am half way around the world. Go to a welding shopand have them weld and plate the frame. should be good.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 01-08-2005, 07:51 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What part of the frame is it...any idea why it is cracked?
Old 01-08-2005, 09:11 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you don't have a welder, just take the shock and upper stud off and drive to someone who does have a welder.
MIG it up and move on to something else. I'm a Dodge guy, we have to get comfortable welding up cracked frames, seriously.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-08-2005, 11:09 AM   #6
Blue Beard
Blue Beard's Avatar
As long as full penetration is achieved on the weld, maybe backed up with a plate...shouldn't be any problems.
If it's due to an accident, I would surely go over the whole frame with a fine tooth comb.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-08-2005, 12:18 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you can get to it, you should drill a small hole in the frame at the end of the crack. This will stop it from going any further, as long as you get it at the end of the crack.
The other suggestions are valid, too.
Member Nr. 2770
Old 01-08-2005, 01:39 PM   #8
rustyold72
rustyold72's Avatar
Will my Lincoln weld pack 100 be enough to handle this, or will I need a welder with more oomf ?
Old 01-08-2005, 06:01 PM   #9
MOTHERTRUCKERS
We drill it at the end of the crack, die grind the outside crack and weld in a washer on the inside of the frame then weld and grind the outside. your Lincoln will do it fine.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-09-2005, 01:43 PM   #10
72dually
72dually's Avatar
Might wanna check the frame around the steering box as well, pretty common to see a crack in the 73-87 frames, I dont know if it apply's to the early trucks
72dually is offline   Reply With Quote
Old 01-09-2005, 02:13 PM   #11
86SILVERADO
86SILVERADO's Avatar
I have a Lincoln 135 and I need to heat the frame in order to get enough penetration to fix that problem. It is common and nothing to worry about but the shock mount bolt does put alot of stress on that area and if you do not get it right it will fracture again on you in short order. You need to drill the end of the crack out as mentioned and a backing washer is a good idea but not necessary. If you have never done it before you WILL have difficulty especially with only a 100. I suggest taking it to a shop.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
