01-10-2005, 09:47 PM | #1 |
Unending Project
Assume I'm an idiot
It usually works better that way... Anyway, My question is about lowering my '66 fleet. I'm almost done with the new front suspension that will sport drop spindles and 3" drop springs. I'm starting to think about the rear, and am wondering about bagging just the back half.
I still want to use my truck to tow stuff and haul stuff, but it needs to look cooler. Should I bag the ass end? How would that help/improve towing over lowering springs? Piper |
01-10-2005, 10:28 PM | #2 |
Happy to be here
If you just want the bags for towing/hauling I would do a static drop, and add a set of helper bags. They work sort of like air shocks, but don't create a harsh ride. They give you as much assist as you need for towing/hauling when aired up, but when not in use they don't affect the ride at all....
01-10-2005, 11:17 PM | #3 |
I will have to politely disagree w/N2TRUX on this one .
I own a 68swb truck that's static dropped 6" up front & has bags + lowering blocks for between 7-8" drop out back. This truck not only rides better than my 5/7" static dropped 74, it will pull that same 74swb on my 18ft car trailer by simply adding a little more air. Why bother w/the dropped coils + helper bags when the bags work effectively by themselves & ride as good as a stock height truck? You can even fill them independently w/schrader valves to keep the system dirt cheap, adding a comp/tank @ a later date if the need arises.
01-10-2005, 11:31 PM | #4 |
Unending Project
ScotI,
That's kind of what I was thinking. Would I just mount a set of bags in the stock spring locations then? I'm assuming that there is some sort of kit out there that allows me to run bags without springs. What kind of drop from that? Piper |
01-10-2005, 11:35 PM | #5 |
Bags by themselves will net about 5-6" drop depending on what brand & how much air PSI you run @ ride height.
01-10-2005, 11:45 PM | #6 |
Unending Project
What is the recommended kit for a guy that want's to bolt it in and run? Where do you guys mount your air tanks to keep 'em outta sight? Any tips on cool as hell engine driven compressors for L6's or is it most electric? What's the typicall install time on a rear only bag kit? Are you using 4 valves for your rear bags to keep the side to side pressure under control?
Sorry bout all the q's, but I figured I'd just take the damn plunge and learn it. Piper |
01-10-2005, 11:57 PM | #7 | |
01-11-2005, 12:38 AM | #8 |
Happy to be here
I don't know why I can't seem to remember to pay attention to what year truck the question pertains to. I was thinking about leaf spring rear suspension when I replied.
Scoti is on the right track. My mistake.... |
01-11-2005, 05:23 PM | #9 |
Got L.E.D.s
For the rear you don't need any kit, just bags, drill bits and drill. And plumbing supplies.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
01-12-2005, 01:39 AM | #10 |
Needs a Big Block
I am running that set up on my 64, I have 3 inch drop spindles and 3 inch springs, I run each bag independently and fill the with schrader valves{ like a bicycle tube fill} at the rear I actually used them as liscence plate mounts and cover em with chrome cap it was dirt cheap and I ust pump am up at home if I wanna dump em at a show and fill em later I carry a portable with me or just drag tail to the nearest gas station and top em up
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
