67-72 Addict!
What's the difference between a 70' and a 71' column?
I need a new chrome gear shifter for my dads 70' but I think his column was taken from a 71' truck because of the pointer on it. How can you tell the differences in columns?. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
The difference is the shift indicator housing, 69-70 used metal 71-72 used plastic, also the pointers for the indicators were different but the mounting holes are the same.
The shifter arms are different too but I am not sure what the difference is Last edited by Gee_Emm; 01-11-2005 at 11:52 PM. |
its all about the +6 inches
yup, the indicator and the pointer are all that's different. And the parts will swap one for the other.
Looks best if you swap the indicator and the pointer from the same era.
67-70 or 71-72.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
67-72 Addict!
The housing and pointer are plastic so I'm thinking it must be a 71'. I guess I'll buy a 71' gear shifter then. I just hate to buy the wrong part and have to send it back. Thanks guys.
