Primer question
My truck is a daily driver and i plan on getting in painted in a few months, but for welding up my antenna hole, emblems, stake pockets, etc i would like to do these between now and then. If i was to weld them and do all the body work and prime over that how long could i have the primer on there? Would it hold up to the rain and weather and not rust? thanks
-Ben P.S. I have this in the paint and body section but i think alot of you people who dont consistantly(sp?) go over there would know.
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
i also dont have a problem with something as simple as re-sanding before paint and minor things
I didn't have a problem with it. My bed was in primer for about 6 months, and I never had any rust come thru. I shaved the stake pockets, and the sidemarkers, (welded all of these up) I used Mar Hyde 2K primer.
was 67 chevy swb fleet now muticolored 69 step, 350/350, 3.73 posi, converted to 5 lug, torq thrust II 17x8 front 17x9.5 rear, factory air cab, fuel cell. future plans: shaved wiper cowl, shave stake pockets, phantom grille, and silver paint... 68 camaro ss396 project 54 f*rd project truck |
Pesemistic Optimist
A good quality epoxy primer should hold up for you. I would post this in the body and paint forum for a better answer though.
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress. 1999 Yukon Denali- Wife's ride, hands off. |
Your UncleBen
![]() Join Date: Dec 2002
Yeah you should have no problems. Just use a good quality primer and you should be fine for just about as long as you need to wait.
Some of my trucks got to primer but never made it to paint. So I know what you are going through... ![]() ![]() lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
Most plain and guidecoat primers are porous. They allow water to microscopically seep thru to the metal and cause rust underneath the coating. If the truck is always inside, doesn't matter. If outside, then only a primer-sealer will prevent water from penetrating the primer(-sealer) coating to the metal. You can leave a primer-sealer on outside as long as it stays bonded to the metal. For your welding work that will ruin small patches of previously sprayed primer-sealer, have the paint shop mix up some primer-sealer in an aerosol can so you can reapply to just the parts you've welded around.
Verify this with your local auto body paint supplier. The staff will likely know this info from experience, whether personal or with customers. Besides, they will give you the best recommendation regarding waterproof primers.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 01-12-2005 at 09:23 AM. |
#7 | |
Keep On Truckin'
4X4Poet is right on the mark. Regular primers may seem to be okay but down the road you run the risk of the paint peeling or rust developing under the paint.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
![]() Join Date: Nov 2004
I used a primer sealer and my truck has been in it since '96........
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
ttt, i have "sem high build primer surfacer" its good primer and sweetandlong said a good primer should do, would this work, could find the product online
