Out draggin'
Can anyone identify these parts????
Below are pictures of an underdash steering column mount and an intermediate shaft from the same column. The column is an automatic tilt... Are these van parts? Motorhome?
The steering column mount has the letters "MNP" stamped into it. It has the same bolt pattern as the stock flat plate that goes under the column and it also has the holes in the same spot for the pedal bumpers... ANY HELP WOULD BE APPRECIATED...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Looks like van stuff to me. The intermediate shaft is way too short for a truck one.
Id put my money on a motor home column and drop mount because the column shaft is short like a trucks.
Rest in Peace Ed. Thanks for all the good times. |
Out draggin'
OK... That's what I thought. Thanks guys....
Without the intermediate shaft(which it looks like you already took off) that col. should be the same length as a true truck tilt col. If it is an early tilt, the PRNDLL should also have early style lettering rather than the later(more common) van lettering style.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow Last edited by Bob Moore; 01-13-2005 at 09:47 PM. |
![]() Join Date: Jul 2004
I have to go with motor home as well ( although I have never seen one ) just for the reason the inter. shaft you have pictured is much smaller than a van or truck one, and the bracket is different as well.
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton 1 incredible wife 2 great kids |
Still drivin' a Rat Rod
Looks just like the one I pulled from a 1 ton van.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Out draggin'
Anyone have a pic of what the differences in the PRNDLL script are?
Thanks! Joe
Prndll
I'll e-mail a picture tonight of both styles. Maybe you could then post it for others.
Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
