I just put a new trans (400 auto) and transfer case in my 67' chevy and I have a vibration that you feel threw the seat. It's not a constint vibration but one that comes and then goes then comes right back again. Only does this at about 55mph and up. I put a new drive shaft on it and I don't hear any rearend noise. I jacked up the back and ran it and it still did it so I don't think it's the tires.. Let me know what you think. Thanks Cliff
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Did you have your new driveshaft balanced?
------------------ Toms River NJ (Transplanted Hoosier) 56 working Street Rod(under construction 71-2 coil chassis) Give a man a fish and he will eat for a day. Teach him how to fish and he will sit in a boat & drink beer all day. |
Yes my driveshaft was balanced. I've got two driveshaft that were built and balanced
for this truck.I'm going to try the other driveshaft tonight. I just can't beleive that Acme driveshaft in Decator Il. would make a bad driveshaft but I guess anything is possible.. |
Had similar problem with my brothers truck. Found out the bearing cups on the rear u-joint were not fully seated against the universal joint. Found it by grabing the drive shaft in the rear was able to feel slight side to side movement.
------------------ 72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans 3" Exhaust W/Headers C30 Frame C10 Suspension Short Wheel Base (Dually)
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
