My rear suspension is a rusted out mess. Found new trailing arms, shock mounts, spring cups. Now it is time to get off the bolts. Any suggestions? Can I grind it off with my grinder? No torch.
------------------ Hoboken, N.J.(home)/ Washington, D.C.(work)
Hoboken, N.J.(home)/ Washington, D.C.(work) |
Senior Moment
![]() Join Date: Mar 2002
LOTS OF KROIL or any good penitrating oil and a BIG breaker bar. Thats what I used and if you clean the showing treads good once you get it going the'll come off. Stay away from the torch, oooh that hurts
Good Luck ------------------ Steve's 70 CST Soon to have a BB
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Strongman Garage
![]() Join Date: Apr 2000
lots of the time the u bolts will rustoweld themselves to the rest of the axle/inside the trailing arms.... best way is to just cut them into two pieces and replace with new
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
Got 20's????
Torch the bolts and you will be done in less than 5 minutes.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
Should I cut off the nuts, or the bolts next to the axle? I was thinking next to the axle. Thanks for the replys.
