Old 01-18-2005, 08:27 PM   #1
454_72_4X4
454_72_4X4's Avatar
VIN decoding help
A friend of mine has a 70-71? truck we've been trying to decode the VIN #'s.
It doesn't seem to match any of the "decoders" we've found, (including here).
Can anybody help us out on this?
Here's what the tag on the left door has;
KE234-SZ@#$%^
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-18-2005, 08:43 PM   #2
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Here is my try at it: If I am wrong someone please correct me.
K = 4 x 4
E = V-8 Gas
2 = 3/4 ton / 5200 - 7500 lb.
34 = Cab - pickup box (for GMC anyway I assume it may be) could be wrong here.
S = built in St. Louis
Z = 1970 for 15 Series
Ok this is my try at it, hope I win the big cookie and this helps.
Mike
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 01-18-2005, 08:46 PM   #3
Rod
KE234-SZ@#$%^
Simple
K = 4x4
E = eight cylinder
2 = 3/4 ton
34 = fleetside box
S = St. Louis assembly plant
Z = 1970
It's a 1970 3/4 ton 4x4 GMC fleetside box pickup.
Not sure where above post got the Z= 1970 15 series...that ( 15 series) is the only thing wrong. Good got someone else to do these now..your faster than Longhorn Man now . And you even beat me to it.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-18-2005, 09:30 PM   #4
454_72_4X4
454_72_4X4's Avatar
Thanks guys.
The "-" between the "34" and the "S" had us bumfuzzled.
All the decoders seem to show the year number to come after the "34" and he just has the "-".
The only "Z" code I could find means Fremont assembly plant but it has the "S" for St. louis plant so I didn't know what was going on.
Thanks again.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-18-2005, 09:41 PM   #5
Rod
70 and 71 GMC vins on some asembly plant lines did it differently like in your case.
The Z still means Fremont plant on many other variations of vins.
Old 01-18-2005, 09:50 PM   #6
454_72_4X4
454_72_4X4's Avatar
His truck is supposed to be a Chevy! It has a Chevy grille and tailgate anyway.
Could be the cab has been changed?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-18-2005, 10:02 PM   #7
Rod
Try to match the cab vin with the frame vin and compare.
Old 01-18-2005, 10:07 PM   #8
bisquik65
bisquik65's Avatar
My 67 gmc has 15 digits in the vin????????????Can anyone decode mine???? I dont want to jump on anyone thread but it is a good one.
CM3640VCZC***** This is a V6 truck and cab and chassis dually
bisquik65 is offline   Reply With Quote
Old 01-18-2005, 10:25 PM   #9
3 on the tree
According to my 70 owners manual: C-96" or 106" conventional cab, M-V6 gasoline,3-6700-10000 GVW, my manual lists a 62 code for body and brake vs your 64; Chassis-Cowl (Full Air), the 0 digit denotes 1970 according to my owners manual so I am lost after this point. Hope this helps a little bit
3 on the tree is offline   Reply With Quote
Old 01-18-2005, 10:12 PM   #10
Rod
not a problem bring it on bisquik65
oh, its there..hmm...thats gonna take bit,..check back in a few
Old 01-18-2005, 10:28 PM   #11
Rod
CM3640VCZC
Gee I dont know ..I saw one like this also..except it was a 4x4 and was KM2whatever..I cant even find the number anymore.
Anyway
C= conventionall cab
M= v6 gas
3 = 1 ton gvw range
4? dont know
0V = cab and chassis
C = 1967
Z= fremont plant
C= dont know
Its like GMC put model numbers for vins ..this makes more than a couple I've heard of like this.
Old 01-18-2005, 10:33 PM   #12
bisquik65
bisquik65's Avatar
I believe this was an EZ HAUL truck that had little eleaphants on the box sides? its is blue and white. It was compatition for U-haul back that era. Not sure. It had a 14 foot box on it that came over the top of the cab
Old 01-18-2005, 10:37 PM   #13
3 on the tree
Does it have air brakes? I'm trying to figure out what some of these abbreviations mean in my VIN decoder in the back of my owners manual?
Old 01-18-2005, 10:31 PM   #14
454_72_4X4
454_72_4X4's Avatar
Where do I look to find the frame #?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-18-2005, 10:37 PM   #15
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Not tryin' to hijack the thread here but i'm having the same problem. The frame and cab #'s match, but the tag on the glovebox says CE234-ZZ51273, not sure what it comes back to???? Maybe a typo on the label or something I guess.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 01-18-2005, 10:42 PM   #16
bisquik65
bisquik65's Avatar
This thread rules. GMC vins are who knows???? This gmc does not have air brakes ,manual steering with 18.5 x 6 split rims. Old skinnies. 5.13 gears with a new process 4 spd with a spicer aux. trans (yea old twin stick) very cool for gas milage
Old 01-18-2005, 10:40 PM   #17
Rod
I wa wondering if the last character on that vin bisquilk is a letter also.?
******B
or like that
Old 01-18-2005, 10:44 PM   #18
Rod
Robert your is fine still
CE234-ZZ51273
C= Conventional cab
E = 8 cyl
2 = 3/4 ton
34 = fleetside box
Z = Fremont Plant
Z= 1970
51273 ... means sequence number.
Old 01-18-2005, 10:49 PM   #19
bisquik65
bisquik65's Avatar
No he is the whole thing on the title.
CM3640VCZC14558 thats all Mabya special vin for a fleet???
Did you get your rivits yet rod???
Old 01-18-2005, 10:48 PM   #20
Rod
frame number is where Longhorn Mans finger is typically..top of rail.. should start with the year then assembly plant and rest of sequence vin.
Old 01-18-2005, 10:55 PM   #21
Rod
No vin rivets yet... mail is slow getting here from US.
I have to pass on figuring that vin bisquik..thats all I can figure for now...I'll write it down and see what I find.... it's one of those odd ones. I've got lots of peeps on this thread answering as I reload the pages. .lol
There's a little better pic of vin on frame.
Old 01-18-2005, 11:10 PM   #22
Rod
CM3640VCZC14558
OK this is what I figure it is bisquik65
I should charge for this...
C= Conventional cab
M = V6 gas
3 = 1 ton
64 = GMC way of stating cab to rear axle dimension..in this case 64 means 84 inches
OV = cab and chassis order designation
C= 1967
Z = fremont plant
C14558 = GMC's starting serial number for trucks produced in USA in 1967 started with a C1*** you got number 4558 out of that plant or perhaps 14558.
