Old 01-20-2005, 12:54 PM   #1
dolanb7
Angry How to remove...
I am trying to get inside my 70 truck door to replace speakers. What is the best way to remove the door handles and window cranks without messing up the panel ect????
dolanb7 is offline   Reply With Quote
Old 01-20-2005, 01:01 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Get one of these. Most auto supply places have them. It's called a door handle removal tool.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-20-2005, 01:04 PM   #3
dolanb7
thanks, i couldnt remember what it looked like, or even if i could find one.
Old 01-20-2005, 01:05 PM   #4
JimKshortstep4x4
Smile
Welcome to the board from West Michigan!
A door/window handle tool works real well and they are available from most parts stores in th "Help" section.
Jim
Old 01-20-2005, 01:06 PM   #5
dolanb7
thanks for the welcome, im clear over here in Nevada and enjoy this board.
Old 01-20-2005, 01:27 PM   #6
Putter
More Cowbell....
Putter's Avatar
Hey, Welcome from Central Mississippi ---You OFFICIAL Hood-Away-From-Home
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 01-20-2005, 03:19 PM   #7
Deuce
Deuce's Avatar
I usually just put a hook in the end of a piece of farmers wire. Fish it in, hook the clip and "pop" it out.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 01-20-2005, 05:28 PM   #8
dolanb7
do the door handle removers come in different sizes?? the one i have isnt working and it seems to be too small???
Old 01-21-2005, 07:41 AM   #9
JimKshortstep4x4
Smile
Which way are you inserting the tool? If the clips are in the stock position, then the tool should be inserted from the roller end on the window handle and on the handle end of the door handle.
Jim
Old 01-21-2005, 08:55 AM   #10
Blue Beard
Blue Beard's Avatar
Welcome from SW Washington State....
That's the ticket for removing the knobs. Been using one for about the last 20 years doing locksmith work on the side.
And they are cheap.
Somethimes those c-clips get put on backwards, so don't force it...try the other side.
Save yourself some trouble when you use that tool, kind of wiggle it side to side as you work it. Those clips have a tendacy to pop off and go flying.
Wiggle it and the clip release slowly and most of the time keeps the clip where it can be found.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-21-2005, 12:57 PM   #11
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I northern hydralic has them
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-21-2005, 08:21 PM   #12
bisquik65
bisquik65's Avatar
The eaisest way i have found is take a shop rag. like the ones that are red at the parts stores. Slide it down behind the handel and pull it toward the clip and twist it around the handle,the clip will get stuck in the rag so you dont lose it...It workes really fast if you dont have the tool. And the rag wont scratch up a good door panel...
bisquik65 is offline   Reply With Quote
Old 01-21-2005, 09:23 PM   #13
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
now question...how do you put the clips back?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 01-21-2005, 09:29 PM   #14
You can put the clips on handle first,then pop in place.Good idea with the rag there.I was going to say,watch the clip flying.
Old 01-21-2005, 09:44 PM   #15
bisquik65
bisquik65's Avatar
Yea the rag deal is a When you have no tools and need one door handle it does work!!!!!!remember this the next time to the junkyard. I can also tell you the bolt in a gm posi carrier when it breaks off in the carrier,i take an antenna off a gm car and find a hot battery and some wire. Take the antenna and hook the hot wire to it,place the tip of it in the hole where the botl is broken off. Then touch the ground wire to the carrier until it arcs the antenna to the broken bolt. then just turn the antenna and that bolt will thread itseft out. I found a posi a needed in a pull it yard and that broke on me. I got it with i little thinking...
