Old 01-24-2005, 01:16 PM   #1
XXL
Señor Member
XXL's Avatar
Xmember install progress
I drove my truck up to slammed67's place this weekend for the xmember swap. Here's progress...
XXL is offline   Reply With Quote
Old 01-24-2005, 01:18 PM   #2
XXL
Señor Member
XXL's Avatar
and then after the refreshments...
Old 01-24-2005, 01:21 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
XXL,... What are you going to do with the old crossmember? I'm looking for one to cut up.
Keith
Convert to disc brakes.
Old 01-24-2005, 07:39 PM   #4
XXL
Señor Member
XXL's Avatar
Old 01-24-2005, 09:39 PM   #5
lolife99
lolife99's Avatar
PM'd you,...
Keith
Old 01-24-2005, 10:09 PM   #6
phantom dually
Project92 SWB stepside
phantom dually's Avatar
R U done yet??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-24-2005, 10:14 PM   #7
XXL
Señor Member
XXL's Avatar
Nice road rash I've got on the front edge of that control arm. Note: Somewhere in Wichita there's a missing yellow dot from the road.
Old 01-25-2005, 01:17 PM   #8
XXL
Señor Member
XXL's Avatar
slammed67 is such a diligent worker. Here's a progress pic...
Old 01-25-2005, 01:59 PM   #9
XXL
Señor Member
XXL's Avatar
more...
Old 01-25-2005, 02:00 PM   #10
XXL
Señor Member
XXL's Avatar
BTW... capt kaos, we discussed potential tie rod clearance issues, but you felt it wouldn't be a problem. Oops
Old 01-25-2005, 02:25 PM   #11
grnddwn
belly dragger
grnddwn's Avatar
I hear grinding noises in your future. I"ve had to do that to every crossmember I've built so far same spot.
grnddwn is offline   Reply With Quote
Old 01-25-2005, 03:45 PM   #12
Slammed67
Progress = 0%
Slammed67's Avatar
Yes, that is what I'll be doing this evening, after a few beers of course
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-25-2005, 03:45 PM   #13
SCOTI
SCOTI's Avatar
XXL, CaptKaos, or Slammed, how much of notch is that crossmember?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-27-2005, 03:11 AM   #14
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
WOW, you are moving along! That piece looks really familiar...
I expected grinding on the lip area, the clearance area I was refereing to that wouldn't be a problem was in between the framerails for the centerlink. Sorry for the confusion.... I appologize.
Originally Posted by phantom dually
OUCH I remember asking those questions to Bill Turner when I was only going to do the member and not the Rack and pinion. He spoke of turning the parts backwards somehow?? Not sure if he was blowing $hit up my ARSE or what??
I am guessing he was talking about flipping the tie rod ends to point up and retapering the spindles to gain clearance at the framerails so they don't have to be notched as much, but... you aren't actually moving the centerlink down, so....
Originally Posted by Slammed67
Did '73+ trucks have such a spacer on them from the factory?? That's the only explanation I could come up with.
This is the way they go. Bevel pointed inside.
The 73-87's have a beveled washer that goes into that "slot", shims are placed between it and the frame.
Is it true that you can use a "VAN" steering box? Like a early to late '70's model? Something about the box being taller, to help clear the upper arm. Seems like "fiveeightchevy" posted. Anyone?
I have heard that, but I haven't found "the box....
It looks like the problem is the ART upper arm width that's causing the real problem. With the stock uppers on there is a lot more clearance (though I don't know if it's enough).
No, It won't be enough...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-27-2005, 11:41 PM   #15
XXL
Señor Member
XXL's Avatar
low?
Old 01-25-2005, 06:20 PM   #16
fastbagged68
fastbagged68's Avatar
How come there is not alot of Pabst Blue Ribbon. I see ALOT of Lite's though. Pabst Blue Ribbon is the poor boy special!
fastbagged68 is offline   Reply With Quote
Old 01-25-2005, 10:33 PM   #17
phantom dually
Old 01-26-2005, 12:16 AM   #18
XXL
Señor Member
XXL's Avatar
OUCH I remember asking those questions to Bill Turner...
But Bill Turner is a nice guy and, for those of you who don't know slammed67, he's quite the bleeding cl!t {inside joke}
Old 01-26-2005, 12:01 PM   #19
SCOTI
SCOTI's Avatar
Slammed, you have PM.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2005, 01:36 PM   #20
XXL
Señor Member
XXL's Avatar
Almost done...
Old 01-26-2005, 01:38 PM   #21
XXL
Señor Member
XXL's Avatar
Let the problems begin...
Old 01-26-2005, 02:03 PM   #22
fastbagged68
Where are your spacers for the upper control arms? You also need your borgenson joints to clear your upper arm, any time you go that low you are going to need to do it.
Where are the budweisers?
Old 01-26-2005, 02:33 PM   #23
Slammed67
Progress = 0%
Slammed67's Avatar
I haven't put them in yet. Look at the first pic in XXL's last post. See how one side of the a-arm shaft where it bolts to the x-member is dished or cupped and the other side is flat? It looks like the dished part matches the curved surface on the cross member studs, but I don't think you'd want to put shims between those two non-flat surfaces. However, if you rotate them so the flat side is facing inwards, then the nuts would be against that dished a-arm shaft. Why is one side dished like that??? The '67-'72 shafts are flat on both sides which makes sense. So which way should they be installed?
Old 01-26-2005, 03:48 PM   #24
XXL
Señor Member
XXL's Avatar
And I've been on the phone with Borgeson this morning... working on a solution.
Old 01-26-2005, 02:41 PM   #25
Izzy
Trucker.
Izzy's Avatar
On my buddies 85 the shop that did the alignment used spacers that were dished to match the shaft on the outside of the spacer stack.
Izzy is offline   Reply With Quote
