01-26-2005, 02:44 AM | #1 |
carl
can someone help please
i need the to know what i have to torque my ball joints and tie rod ends at, can someone help me please? i am putting my supsension back together sometime this week. thanks you it would be deeply apprieciated
a man and his truck, such a beautiful thing
01-26-2005, 08:44 AM | #2 |
Watch out for your cornhole !
I've been waiting for someone to offer you the help you need on this.
Let me tell you what every mechanic including myself does. Freaking pull hard on the wrench. Then, tighten it even tighter till the hole lines up, never loosen it. I couldn't even imagine how may balljoint and tieord castelated nuts I've tightened, and every one of them has been a real hard pull on the wrench, then more until the pin lines up. Never had a trouble.
01-27-2005, 03:47 AM | #3 |
carl
thanks man, finally someone, i wasn't tottaly sure and i wanted to be correct. from my reading you always seem to come thru in the clutch. thanks again, later
01-27-2005, 02:51 PM | #4 |
torque it down till it strips then back it off 1/4 turn! j/k
01-28-2005, 09:52 PM | #5 |
too many toys
tork the tierod ends to no more than 55 lbs then till the tiny little hole for the cotter pin lines up. The ball joints to 90 lbs. .
if we were all fatter we'd be closer together 1971 gmc 3/4 4x4 383 stroked 1968 1/2 2nd owner 4bbl 6cyl 1969 gmc 3/4 4 sale 350 4bbl 4spd 1969 chev 1/2 lowered 5 spd 454 4bbl 1947 chev coupe 2002 harley flhtcui 6 -67-72 my parts |
01-29-2005, 08:23 AM | #6 |
Generally in situations like this if you torque the nut to the specification of a grade 5 bolt of the same diameter, you will be fine. Like Tx Firefighter said...once you are tight, do not loosen it to align the cotter pin slot. Tighten it more, until you get to the next one.
01-29-2005, 08:34 AM | #7 |
F.A.S.T. president
Also make shure the tapers are nice and clean, avoid having a lot of paint on the tapers as well. A little anti seize and no paint works best.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
