Old 01-29-2005, 04:03 PM   #1
nu2-72
Need lockout lube info- general
I am working over the new lockouts today and reading the factory service manual.
We all know this is 30+ year old information.
What are you using for lube on the lockouts, chassis, all greasable points on these old trucks?
There have to be much better choices these days. I would guess that some are advertised as the all around lube. But, there is probably a best for each use.
What do you use for the diffs., transfer case, tranny and joints? 2wd or 4wd. Synthetic greases, lithium or what.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 01-29-2005, 10:09 PM   #2
Gator70
Gator70's Avatar
This is what I use:
If chassis parts are in "very good shape" I use synthetic chassis grease. If the boots are cracked then its a waste. Regular chassis grease is better.
For u-joints regular chassis grease.
For diffs. synthetic 75w90 - a friction modifier is not needed with this syn oil.
For the hubs I use a white lithium grease.
Wheel bearings I have used synthetic grease but havent seen long term results yet.
Auto tranny regular Dexron
Transfer case- depends on recomm fluid. If gear oil then syn 75w90, if atf then I am thinking of trying GM's new AUTOTRACII, have to do a little more research before I change out to that.
Motors-always synthetic, with no other "snake oil" additives.
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
Old 01-29-2005, 10:15 PM   #3
nu2-72
Follow up question.
By hubs I assume you are talking about the lockout hubs. Why synthetic for the wheel bearings and white lithium for the hubs, not syn. for both?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 01-30-2005, 07:01 AM   #4
4x4Poet
The disc brake hub wheel bearings require disc brake high-temp rated grease, whether conventional or synthetic, but the lockout hubs don't. In fact, disc brake high-temp grease goes goey easier than non high-temp wheel bearing or chassis grease. The lockouts need a grease that will stay in place and not ooze into the wheel hub, so I use a grease with good thickeners. You want a grease with good thickeners for the u-joints and steering joints (TRES, etc.) since it also must stay in place to work well. I splurge on Amsoil for most everything. IIRC, Amsoil offers three different greases that meet my trucks various needs.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-30-2005, 11:05 AM   #5
nu2-72
Thanks.
Knowing the lockouts would only get occasional use, winter cold mostly, I wanted something that will hold up to extreme cold and remain pliable. But also survive the summer heats. I don't mud so deep water or mud is not an issue.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
