01-31-2005, 03:09 PM | #1 |
71 bb longhorn
Cd player install
Has anyone tried or has had their stereo installed in the glove box.( I am going to put the original Am radio back in to keep the vehicle stock looking) I am trying to think of a good place to mount it where it would be fairly accessible. any ideas as how to mount it in the glovebox ?
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. |
01-31-2005, 03:12 PM | #2 |
when I had mine in the glovebox, i just kinda set it in there, didnt hold it down with anything. it worked pretty good and never skipped. i did clear out some space in the rear so the heat sink wouldnt be touching the cardboard, tho.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-31-2005, 04:16 PM | #3 |
71 bb longhorn
Did you have the stock liner in you glovebox or did you fabricate something ?
01-31-2005, 04:27 PM | #4 |
I shipped mine today to have the original AM converted into a AM/FM with the jacks on the back for a CD player or sattelite radio. I think that it is a good way to go, but is pretty expensive.
01-31-2005, 04:32 PM | #5 |
Member since 2000
many moons ago when britney was drivable i had the head unit in the glove box. Just slapped it in there and slap some back strap to hold it down. IT worked fine.
01-31-2005, 04:38 PM | #6 |
Had the deck and disc changer in there!
Use the 4 screw holes that hold the glovebox in so there is no mods! Rest the weight of it on the heater I used a big sponge inbetween the wood and heater box! Cheers
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:29 PM. |
01-31-2005, 05:01 PM | #7 |
71 bb longhorn
I want to be able to have the glovebox door closed so the stereo can not visible as I will be applying for colletor plates when the truck is finished.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. Last edited by bc gman; 01-31-2005 at 06:59 PM. |
01-31-2005, 05:07 PM | #8 | |
computer illiterate
where did you send it to? I am interested in this.
72 2wd blazer 72 swb 4x4 |
01-31-2005, 06:15 PM | #9 | |
01-31-2005, 07:03 PM | #10 |
71 bb longhorn
70c-10 did you use the AC liner to make your glovebox or is that the original liner. What you did is what I was thinking of doing looks good. Jerry
01-31-2005, 05:48 PM | #11 |
The door closes fine and dandy? ?The pic shows the piano hindge at the bottom!
Good Luck! If you were close I'd put it in for ya! |
01-31-2005, 06:11 PM | #12 |
67-72 Addict!
This is how I did mine. I used a AC liner because the rigid cardboard is strong and helps support the radio nicely. I made a sleeve out of sheet metal and rivited "L" brackets to the sleeve then rivited the sleeve to the glovebox liner for support. Slide the radio in and put screws thru the sleeve. I then trimmed it out in ABS plastic. I used bullet connectors to remove/repair anytime I want. I am installing a unit soon in my dads truck and plan to do something different with his to incorporate CD storage. Here are a few pics I found. Hope it helps.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-31-2005, 09:04 PM | #13 |
67-72 Addict!
Jerry, I used an original AC liner and just cut out the opening. My truck has no AC in it.
01-31-2005, 10:58 PM | #14 |
GM ONLY BABY!!!
You could make a console for the cd player. That's what I did. The console also holds my aftermarket guages and drinks. I made the console fit tight, and didn't mount it to anything. Therefore, I drilled no holes in the lower dash. I made it out of 3/4" particle or wafer board, and covered it with speaker box carpet. I am considering recovering it with green vinyl in order to match my interior. You can check it out on my link at the bottom of this post.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
01-31-2005, 10:59 PM | #15 |
Got Light Emitting Diode?
gees guys, just cut the dash and be done with it
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
02-01-2005, 01:32 AM | #16 |
huh ???
This is how I'm thinking of doing mine. I like the look of the radio delete in the dash...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
02-01-2005, 04:02 PM | #17 |
GM ONLY BABY!!!
If you guys use you glove compartment for the cd player, where do you put all of the stuff that would usually go in the glove compartment? Like fuses, and the registration, and insurance card, and napkins, and lug nut key, and cd player faceplate container?
02-01-2005, 04:09 PM | #18 |
67-72 Addict!
I still have plenty of room as you can see in my pic.
02-01-2005, 04:15 PM | #19 |
Just a question, but has anyone tried putting the stereo in a center console, like the one that came with the original buckets. I don't mean create one under the dash, but use an actual center console, an original or something out of a newer truck, where you could close the top and "hide" the stereo. This would also give you very easy access to the stereo instead of having to reach across the dash to change cd's....just a thought. Anyone done this or have pics???
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-01-2005, 05:43 PM | #20 |
K series consols are great to work with!
You can cut and paste some fiberglass to them for more option or to cover more space! |
