Needing Rh Exhaust Manifold
Needing a RH exhaust manifold for my Dually. 350 engine, the manifold runs down below the spark plugs, the dump sweeps back at the end of the manifold, and the "extension" is very long, equivalent to having a heat riser on it, I'd say. But it does NOT use a heat riser. I have a 4X4 dually, just like it, and it uses the same manifold as 4X2. Actually needing the same manifold for BOTH trucks! If you have one that you can sell me, please let me know. Many Thanks
what year??
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80 2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc. 2003 Tahoe Z71 Silverado front clip |
Rusty Rockerfeller
![]() Join Date: May 2003
Ex Manifolds
Both trucks are 1989 but the bodies are the generation before that (73-87) because they are 1 ton duallies.
Similar
They look ALMOST like the ebay link, but the exit dump is longer! The ones pictured, I have, and it was too short. Won't reach the exhaust pipe! It's almost like it needs a heat riser in between to be longer!
I have one off a 89 suburban 350 R/V old style....will that work??? It needs new studs put in,i can do that if it will work.. $45 shipped
