02-03-2005, 04:01 AM | #1 |
Belltech springs
I got some belltech lowering springs of my girlfriends 88 GMC Sierra, (Lill on the forum btw) That car is bagged now, so i wonder if they goes on my 80s truck? And how much can i cut away from them ?
My truck is lower in the back now (Belltech 4" drop) I just want the "cowboy" look for a few months before the flipkit, 3" drop spindles etc is here The truck is missing one round of spring on the originals now.. Cowboy look= lower in front than back
http://www.moldestuket.com 1971 Mustang Mach-1 429 CJ-R 1973 Mustang Mach-1 289 1975/71 Pontiac Firebird Formula 400 1978 Chevrolet C-10 Fleetside Longbed Scottsdale 1980 Pontiac Phoenix |
02-03-2005, 08:11 AM | #2 |
Watch out for your cornhole !
The springs are different.
The 88 and newer style of trucks has straight wound springs. The 63-87 trucks have a taper on the last coil of the spring. You have to have the tapered end to locate it correctly in the upper mounts.
02-03-2005, 08:17 AM | #3 |
Notice the first spring has the same diamter top to bottom. The second spring has a tapered section on one end. That's the difference between the two.
02-03-2005, 05:16 PM | #4 |
Doh!!!
Thank you very much TX !!! Do you know how much i can cut the original springs? They are shaved one round now.. We use to cut 3 rounds on mustangs..
02-03-2005, 05:21 PM | #5 |
www.73-87chevytrucks.com
I don't recommend going over 1 coil on the trucks. If you want more drop, go with spindles.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
