Old 02-04-2005, 09:18 AM   #1
norville
2" drop on the front of an '87 shorty
Hello,
I'm thinking of using springs to drop the front of my 87. Here's the catch I have a v6. So do I need to order 3" drop springs??? my truck sit's close to level now and appears taller than most I've seen locally. They could be newer springs. Anybody have any Ideas??? I'll be doing a 2" shackle in the rear. As much as I want to go lower the roads and my driveway will not allow it. And I'll be running 29" tires.
thanks
norv
could someone drop this pic 2" for me.
thanks
1986 C10 Scottsdale
5.3, TH400
norville is offline   Reply With Quote
Old 02-04-2005, 12:41 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Your truck looks pretty level now, so I think you should keep the same amount of drop front and rear. I haven't really seen a shackle drop, so I don't know if it's a true 2" or not. For example, a 3" spring drop may not be a true 3". It might be really close after the springs settle, but it's hard to tell until it's installed and driven. I would just go with 2" for now, let everything settle, and see how it sits. I went with 5" drop springs on the rear of my 68 and cut the front 1.5 coils, but my truck had lots of rake from the factory. Hope this helps some.
dave2953 is offline   Reply With Quote
Old 02-04-2005, 12:47 PM   #3
norville
Thnaks dave2953,
I guess my big concern is wether the 6cyl engines weight will effect to loading of the springs. Does the factory use the same springs for 6 and 8??
norv
1986 C10 Scottsdale
5.3, TH400
Old 02-04-2005, 12:55 PM   #4
Shev
Head Peon
Shev's Avatar
You could always just lop a full coil off the top of the spring and see if you like the way it sits and rides. Alot of guys on the board have done and have had no problems with it and say it equals about a 2" drop. Just make sure you do a complete coil and don't heat the spring up too much doing it (use a cutoff wheel) Just FYI...my '88 burb was lowered 5" in front and I never had a problem with driveways (even steep ones0 or roads running a 30" tire...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 02-04-2005, 01:04 PM   #5
norville
Shev, Welll you hit that one right on the head... I thought it was 3" per coil. So with that and some shackles I should have a sportier looking truck. I'm sure I'll want more .... maybe. This should keep me happy and an easy project too.
thanks
norv
1986 C10 Scottsdale
5.3, TH400
Old 02-04-2005, 05:40 PM   #6
Shev
Head Peon
Shev's Avatar
It may be 3" per coil...I've been wrong before
I've got a DJM shackle and hanger kit if you are interested...I bought it for my '88 burb and never used it, burb and truck hangers are different. If you are interested pm me and I'll cut ya a deal...
Old 02-04-2005, 06:58 PM   #7
AirMale
AirMale's Avatar
I have a set of 1 1/2" western chassis coils that I cut a full coil off of. You can have them as soon as I put my bags in, just pay shipping. These should be 2 1/2-3" of drop for ya. At least you'll only be out shipping if you want to change your mind...let me know. Jay
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 02-04-2005, 07:52 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You cut the bottom of the spring, not the top.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-04-2005, 08:16 PM   #9
Fat Tom
You could just use a 2" drop spindle, then you know your gonna get 2" and no more or less. A 2" drop shackle kit should also give you exactly 2".
69 GMC 2wd 350cid
82 Toyota 4wd, 3.8L V6, 6" lift, 35's, locked and loaded
76 Datsun F10 1.4L ***FOR SALE***
04 Honda Shadow 750
Fat Tom is offline   Reply With Quote
Old 02-04-2005, 08:32 PM   #10
norville
Airmale, Pm me.. When you get your bags installed you got a deal... 18707
Shev did you say they are not the same. I have an 87 2wd short bed truck. I'd be interested if they'd fit...
thanks folks
norv
1986 C10 Scottsdale
5.3, TH400
