New to Board and need help. 67 swbin New Mexico
Hello everyone. First time poster(now my second post) but I have been trolling the board for a couple of weeks getting some good info. Now I have a question. I’m working on a 67 SWB. It is a frame off and as many of you know you change ideas many times as you go. I have converted the Front drums to Disc. I used my original cross member and A arms. I got 71 ball joints and spindles. This all bolted up fine. Of course the ball joints off the 67 were not long enough. I had all new 67 tie rods and such. Of course they would not work either. Got the new 71 replacement parts and installed them. I’m putting in power steering also. The 71 steering gear box does not bolt up flush to the frame like the old steering box did. I guess I can put some kind of spacer in to get it square to the frame.(any suggestions would be great) Also the Pitman arm and Idler arm don’t look like they will match up to the center link(center link is rubbing on Cross member) any ideas. Learning as I go.
my gas saver
67 has no dimple in the frame like the later years.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
Not too old to learn
Looks like your doing the same thing I am on my 68 only I plan on using a 1969 1970
linkage to avoid the dimension problems you are running into. Mime will remain drum brakes. The problem I have is the center link must be changed to a manual type for the PS box the hook up. As far as the box not bolting up to the frame, you will find you will need to modify the frame be heating the spot and dippling it so the box lines up with the bolt holes with no spacers.You will get more from other members about this I'm sure. Welcome you will get lots of help.
1968 C10 a way to long restoration. |
Welcome from SW Washington State...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Welcome to the board! Where in NM are you located?
78 C10 LWB Super Cheyenne Last edited by 68jimmy; 02-09-2005 at 06:42 PM. Reason: edited |
member #16
![]() Join Date: Dec 1999
welcome Top Pop, here is a pic of the frame dimple some one posted before. Alot of people heat the frame and hammer a dimple in. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Logan
Welcome from Southern MN!!!!
Designated A-hole!
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Welcome to the board. 8Door is right, you definately want to avoid using spacers. Your drag link question I cant help with, because I never ran in to that before.
You can cross reference these MOOG to cheaper parts, you need the K6096T idler arm and the K6143 pittman arm for a power steering 2wd 71-2 setup on a pre 71 crossmember.
Rest in Peace Ed. Thanks for all the good times. |
American Woman!
Welcome!
I'll order them .thanks
Thats the Hillbilly way
Welcome from SoCal.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
