02-09-2005, 06:00 PM | #1 |
Not too old to learn
Center link needed
Looking for manual center link to replace ram power steering on my 68.
I believe it should be a 69 or 70 to fit correctly. Pic shows 21 1/2" between tie rod mount holes. Anyone in So Cal? Chris
1968 C10 a way to long restoration. |
02-09-2005, 06:04 PM | #2 |
Here is pic of ram system that I removed.
02-09-2005, 08:27 PM | #3 | |
Bloo
ive got a 1970 manual steering center link.... $35 obo plus shipping
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
02-10-2005, 11:18 AM | #4 |
What is the difference between manual and power centerlinks? Sorry for intruding on the thread...
02-10-2005, 12:34 PM | #5 |
The Ram assist System (Vette style) has the control valve threaded on to the end off the center link, and the pitman arm ball stud is reversed!
02-10-2005, 01:11 PM | #6 |
Can't ya just remove the ram part and keep the original center link? I'm not familiar with the ram setup though. Am I missing something?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
02-10-2005, 02:03 PM | #7 |
Thanks I think you guys are on to it.
I'll strip the ram piston off and see how it line up. tmad: I got a ps box out of a 70 and will try your suggestion of bolting to frame. What kind of spacers did you use? Chris
02-12-2005, 06:16 PM | #8 |
Still looking for center link in Southern Calf. I had a call but was the wrong one.
I need to see it. Also need the shaft coupler (some call it a rag joint) Must be for power steering box a mnual won't fit different diameter shaft.
