02-10-2005, 03:26 PM | #1 |
Narcissistic Prick
Oil/Water In Air Filter Housing
While checking the condition of my air filter today, I noticed that the inside of the housing was wet with an oily/watery substance. Additionally, the little foam thingy in front of the tube that runs into the valve cover was also saturated. I'm no expert (obviously), but that doesn't seem right to me. I hope the pic below clears up my "thingy" reference. Any words of wisdom would be greatly appreciated.
02-10-2005, 04:35 PM | #2 |
Insert Witty Text Here
I am interested in this info as well. I recently noticed that my crankcase-vent-filter-thingy is covered in watery looking oil, and the oil cap from the valve cover is covered in that same milky goo. My truck is driven enough that it should be able to burn the moisture out of the engine daily, so I am afraid I have a cracked head or blown headgasket.
All of the parts in my PCV system are only right at a year old, so I do not suspect them as being the problem. Slonaker |
02-10-2005, 05:26 PM | #3 |
A soaked breather element usually points to a bad PCV valve, although excessive blow-by can also do this...
Semper Paratus |
02-11-2005, 12:25 AM | #4 | |
Slonaker |
02-10-2005, 08:22 PM | #5 |
I had the same problem with my stock set up. I could'nt get it to stop. I got a valve cover breather and taped over the hole in the air cleaner assembly, problem solved.
82 C-10 Scottsdale LB owned since 89 350 crate vortec heads Crane 1.6 full rollers edelbrock 1406 edelbrock performer eps intake dynomax headers/flowmaster 70's BTO 700r4 level 3 custom 2 piece driveshaft 12 bolt gov loc w/3.08 |
