Old 02-11-2005, 11:39 PM   #1
cysko9
MI '69
cysko9's Avatar
Compressor and Tank Location
Where is the best place to mount tanks and compressors on a SWB fleet side?
I was thinking on the outside of the frame rail somewhere under the bed, possible right in front of the rear wheel well area...
any ideas? im running front and rear bags also, so if you want to suggest a tank size that would be nice also. I probably won't need a huge amount of air, just enough for one trip up. Id even be willing to fill the front, wait for a refill and fill the rears or something.
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline   Reply With Quote
Old 02-12-2005, 12:05 AM   #2
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I just wouldnt put them where it would be impossilbe to get to unless the bed was off. Once your broke down in the middle of nowhere with no way to take the bed off youll think twice about hiding everything too good. Just my opinion. I plan on putting a bed cover on to keep it safe.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 02-12-2005, 12:18 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's my set up...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-12-2005, 12:18 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
2.........
Old 02-12-2005, 12:19 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Valves.....
Old 02-12-2005, 12:19 AM   #6
cysko9
MI '69
cysko9's Avatar
good point. do you think it would that difficult to work on things there?
i don't nkow, i mean its pretty open there, and things would be on the outside of the rail.... i guess i'll just have to see how things fit first... to make a final decision... the bed is a good idea though. do you plan on putting it all in some kindof a housing or just setting it all out?
1973 K5 Blazer
Old 02-12-2005, 12:23 AM   #7
cysko9
MI '69
cysko9's Avatar
very nice setup you have there...
you woudln't happen to know if i can put that late 70's style gas tank on my 69 would you? b/c I was planning on putting a tank where you have your tanks, but I do like that setup you have there.
1973 K5 Blazer
Old 02-12-2005, 12:26 AM   #8
cysko9
MI '69
cysko9's Avatar
where are those valves mounted. is that under the back of the cab??
1973 K5 Blazer
Old 02-13-2005, 11:09 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Those are mounted under the driver side of the cab. My exact set up won't work for you because you need to mount your gas tank where my air tanks are at.
The "best" solution to your gas tank is contact Fuelcellguy and get him to fix you up.
Old 02-12-2005, 03:17 AM   #10
bagged69c10
I have "heard" that you can take a gas tank from like a 72 blazer and it will fit just perfect. I am just going to have it out in the bed under the cover, I just know that I am not going haul anything in my truck with a huge notch sticking up out of the bed and a bed cover. At least everything will be out of the weather therefore less chance of shorts and stuff.
1965 c-10 long bed
1993 Sierra x-cab
Old 02-12-2005, 04:13 AM   #11
MrShelley
Too Many Clubs Club
MrShelley's Avatar
How about under the bed, in front of the rear wheels like this...
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 02-12-2005, 08:01 PM   #12
cysko9
MI '69
cysko9's Avatar
That under the bed steup is pretty much what i was originally thinking about....
You wod'nt know how much clearance there is between the frame and the bed would you? (side to side)
1973 K5 Blazer
Old 02-12-2005, 08:12 PM   #13
72dually
72dually's Avatar
anymore detailed photo's MrShelley?
72dually is offline   Reply With Quote
Old 02-12-2005, 08:54 PM   #14
MrShelley
Too Many Clubs Club
MrShelley's Avatar
This is the only other pic I have of that truck. I took these pics at SuperChevy in Baytown last summer. You might want to check with N2TRUX or STP67-72. I think they know the guy who owns this truck and could possibly get you some more info.
Old 02-12-2005, 09:27 PM   #15
cysko9
MI '69
cysko9's Avatar
yah, thats a nice looking one. (even though im not such a fan of the front being so low like that. I like a nice symmetrical looking wheel. but yah, thats a nice one
1973 K5 Blazer
Old 02-13-2005, 12:31 PM   #16
72MARIO
72MARIO's Avatar
I would not use a Blazer tank go to a 20 gallon fuel Cell with a sending unit From Summit I think it was a 20 x 24 x 10" deep.. You will most likly have to run the filler thur the bed floor. The blazer tank hangs low and you have to cut the rear bed cross member out completely.As for the 73 up tanks they will not fit there cabs hump up to allow room for the tank to fit. I would look at putting the tanks under the box infront of the wheels like trh epic shown. They will get stoned though so mably on the outside of the frame onder the cab.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-13-2005, 06:21 PM   #17
cysko9
MI '69
cysko9's Avatar
72, im a little confused by what you suggested...
Where are you suggesting i mount that summit tank? in the rear where the spare tire goes? or up under the cab?
1973 K5 Blazer
Old 02-13-2005, 08:58 PM   #18
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Mounting the compressor on side of frame is pretty standard. A rock isn't going to hurt the tank. If concerned spray it with Truck bed liner. Mounting everything under the truck saves space. Be sure to select a sealed compressor. Not all are.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 02-13-2005, 09:52 PM   #19
cysko9
MI '69
cysko9's Avatar
bagged, do you have any pictures of your setup? where did you mount your stuff?
1973 K5 Blazer
Old 02-13-2005, 09:55 PM   #20
bagged72blaz
Got L.E.D.s
I'll post pictures soon, but I have two custom aluminum tanks in between frame running crosswise in the frame, and the compressor mounted on the inside of the frame rails. I will be mounting tanks under the hood, and another compressor also. I will get pictures though need to get some of my exhaust.
Old 02-13-2005, 11:26 PM   #21
cysko9
MI '69
cysko9's Avatar
Thanks, i'll get in contact with him.
can't wait to see your pics.
1973 K5 Blazer
Old 02-14-2005, 01:18 AM   #22
bagged69c10
No I dont have any pics of the setup because it isnt all where I am talking about putting it.
1965 c-10 long bed
1993 Sierra x-cab
