![]() Join Date: Jun 2002
Cab???????????
How Do You Tell A 67 Big Window Cab From A 69-72 Cab? Was It Only In 67 That Had A Small Window. Thanks,buddy
Got Light Emitting Diode?
67 had the only small back window, as to tell the vin plate. there are other little things, like the side vent handles are different on 67-68, location of mirrir 67-70, and other little things i dont know
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
The firewall has holes for the foot E brake and Cable operated gas pedal on the 69-72 ? The copperhead Cab was actually a 72 Style he called it a 67 But I know it isnt'
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#4 | |
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
TOTY 2006
![]() Join Date: Dec 1999
The dash is different. More specifically, the ignition hole, and lighter hole, are not the same. Don't have pictures to compare, but I you need that, let me know.
my gas saver
the glove box door in a 67 (if it`s og.) will have a crinkled black finish on it too.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
Cab?????????????????????
ttt
its all about the +6 inches
The 67/68 will have a hand brake for the parkign brake, also the fuse box is mounted 45 degrees off from the later rigs, the aformentioned things too.
user # 2756
![]() Join Date: Jun 2001
nope 71 was first year for cable, prior to that was a rod.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
![]() ![]() Join Date: Jul 2002
No 69-70 were rods!
Since they have rods, they become hot rods without much effort ![]()
