I need some information on the stamp pad #'s on a couple motors.I have a castings #'s book,but have not been able to run down the stamped #'s on any of the stamped #'s websites.The 1st one has casting # of 3970010 = 69 and up 350, with stamped # VO223TDD.The 2nd has a casting # 3970024= a 307 '69-73, stamped # TO51700A.
1972 TDD 350
1980 TDD 350 conv.cab m/t L LS9 155 4 C-20 & 2500 and this is as close as I can get to the 307 1968 DA 307 man trans, 3 spd - 200 2 A F X
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
try............... www.mortec.com ...........great info there
Dan. 55 F100 panel truck project 64 ![]() 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 ![]() 83 ![]() 88 ![]() ![]() 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops ![]() ![]() ![]() ![]() ![]() Last edited by TRUCKGUY; 02-15-2005 at 12:27 AM. |
ttt
well I nailed down the first one...I believe if you look close at your numbers on the 307 closer..its probably a DA....
