4.10/4.11 gear question?
When did the change come about, which is newer?
I think that only the Dana rear ends had 4.10s and the Corporate/Eaton rear ends had the 4.11s. I've got the original Corp/Eaton rear in my truck and it has 4.11's.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
The difference is in the gear teeth.
4.10 is 41-10 4.11 is 37-9 They were used it different housings. 4.10 was in the 8.5" Corporate they were used in: 77-87 K10 and K20 front 77-91 K5 front 80-02 C/K10 and K5 rear 4.10 was also used in 8.875 (12 bolt) truck 64-82 K5 K10 K20 rear 4.10 was aslo used in Dana44 axles 67-76 K10 K20 front (though the ending year is not absolute, they used what they had) 4.11 was a Chevrolet car ratio in the 10 bolt versions. 12 bolt cars are available with either depending upon application or brand. 4.11 was also a 9" Ford ratio. The ratio difference is unimportant......many trucks have slightly different ratios front to rear. |
Got Big Block?
FWIW, I heard the 4.10 ring and pinion gear was stronger, can't remember why. I think the number of teeth on the pinion...
"Experience is what you get when you didn't get what you wanted." |
user # 2756
![]() Join Date: Jun 2001
don't forget about 4.09s, also has to do with thin and thick gear sets around the carrier breaks.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Ive heard that trucks got 4:10 and cars got 4:11 as a rule of thumb. My 67 c10 has 4:10's in the 12 bolt factory rear.
it just depends on the axle. like previously said, the Eaton has 4.11 gears instead of 4.10, and it also has 4.57's instead of the normal 4.56's, and 5.14's instead of 5.13's.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
I pulled a 72 eaton axle from a wrecking yard and the gear count is 41 and 10
so the corporate eaton drop out style also came with 4.10s
