Old 05-30-2002, 01:37 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Question Please look. I have problem
Okay, my tranny still isn't right (700R4 with fresh rebuild). I hooked up a light to the lockup wire going into the tranny. It seems like there is power going to the lockup. When ever I hit the brakes the light goes off and same when I get on it hard. I am still not getting 4th gear it seems. Any other ideas you guys have? This crap is really getting old, I just want to drive the truck and forget about it.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 05-30-2002, 03:05 PM   #2
Brian19692
I read somewhere that the converter is suppose to unlock when you hit the brakes. I don't know about getting on it .
67 short 2wd. FOR SALE
69 long box w/72 grill
69 Camaro 327 4-speed
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
Old 05-30-2002, 03:19 PM   #3
Blue68
Blue68's Avatar
It sounds like it's wired correctly. THere are usually two ways to disengage the lockup. One is with a brake switch (mounts in place of the brake light switch and operates both) and the other is usually a vacuum switch. When you get on the engine the vacuum drops and will break the connection, allowing the torque converter to unlock. Another feature of some wiring setups (Painless wiring for example) is that the converter will only lock up in 4th gear. This can only be noted inside the transmission though. So you can get a signal to the converter in any gear, but the transmission has to say 4th before the lockup will occur.
It sounds like your question may be why is the tranny not going into 4th?
How are your shifts between the other gears? Do they seem late or early? This could be an indication the TV is not adjusted correctly. I can get into 4th with lockup around 40-45 mph if just easily cruising.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 05-30-2002, 04:00 PM   #4
bigvinnie
bigvinnie's Avatar
sounds like the wiring is doing what it's supposed to do.... as far as 4th is concerned, you should be able to feel the gears change.... Have you double checked the shifting to make sure you're really in 4th?....have you counted the gear changes from a dead stop to verify that you're only getting to 3rd gear? ..... a good ballpark method for setting the tv cable is to have the cable at max extension when the carb is at WOT.... then take it somewhere and have it dialed in...
if you've done these checks and you're not getting into 4th, you've got internal issues and I suspect it will have to be pulled to correct the problem... I got good at pulliing my 700 when I was having problems.... I could have it sitting on the tailgate in 35 minutes... good luck
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-30-2002, 04:15 PM   #5
Fast68Chevy
Fast68Chevy's Avatar
yeah have you carefully listened and counted number of shifts from dead stop to make sure tere are three of them ?
Fast68Chevy is offline   Reply With Quote
Old 05-30-2002, 04:22 PM   #6
Mixup
The converter is not the problem and neither is the cable. It sounds like an internal problem. You said it's a fresh rebuild who did it ? Take it back to them.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-30-2002, 04:22 PM   #7
snow man
Lightbulb tranny
you might want to check the valve body it only take a small piece of dirt to hang it up to keep it from shifting.i went trough this problem when i rebuilt the 700 r 4 for the boys blazer. snow man
snow man is offline   Reply With Quote
Old 05-30-2002, 07:55 PM   #8
72chevyLWB
Got 20's????
72chevyLWB's Avatar
we put it up on a hoist tonight and ran it. It is getting 4th gear perfect. The linkage was a little messed up though. The lockup must not be working. I can't feel or hear it unlocking or locking. I am running 2,500 rpm at 55 in 4th and 3,500 rpm at 55 in 3rd. I heard and counted the shifts. but no lockup rpm drop. It should drop from 2-400 rpm when it locks up. I have 27" tires and 3.73 gears in the truck. At 75 I am running 3,500 rpm.
Will this ruin my tranny if its not locking up?
Old 05-30-2002, 08:43 PM   #9
bigvinnie
bigvinnie's Avatar
it's not a problem to run in 4th without lockup, you just don't get the benefit of less rpms on the hiway... 3500@75 seems kinda high even without lockup however... I would have expected it to be closer to 3000, then about 2750 with lockup... someone posted a link to a site a while back that had good stats showing rpms for various gear and tire combos for a 700.... wish I would've saved it......????
72 Stepside Project
Old 05-30-2002, 08:46 PM   #10
racedvl
racedvl's Avatar
They sell non-lockup converters. So I don't think you are hurting the tranny.
racedvl is offline   Reply With Quote
Old 05-31-2002, 03:45 PM   #11
Blue68
Blue68's Avatar
http://www.700r4.com/SpeedOCalc/?calc=1 is where the calculator is. You should be turning about 2500 rpm at 75mph in 4th and about 3500 in 3rd (1:1). Put it up on the hoist again and touch your brake and see if it drops. You may be getting lockup in 3rd but never attaining 4th gear. It will sound/feel similar. Since it sounds like your wiring is correct, touching your brakes will result in an increase in rpms, even in 3rd.
I still think you are not getting to 4th gear. As for ruining your tranny without locking up... it is possible due to heat buildup. But since I don't think you are getting to 4th anyway, you will be as okay as anyone running a th350 with 1:1 ratio.
Old 05-31-2002, 07:47 PM   #12
72chevyLWB
Got 20's????
72chevyLWB's Avatar
when I touch the brakes in 3rd or 4th gear the rpm's decrease. They do not increase at all. I cannot feel lockup at all. I can hold the shifter in 3rd gear and when I put it in 4th it shifts. At 700R4.com they don't ask for the gear ratio though right? Is the stall maybe large enough just to slip to give me higher rpms?
Old 06-01-2002, 02:43 PM   #13
Smitty
Smitty's Avatar
It makes a difference which pin you have your hot wire going to at the plug in the transmission. I think fourth is the front one closest to the trans body.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
