Old 02-19-2005, 12:37 PM   #1
59Apache4WD
59Apache4WD's Avatar
Newbie needs help
The '59 fleetside is scary on the freeway,aiming it down the road is a process of herding rather than steering.......so i got new tie rod ends. Its 4WD with running gear out of a '74 K10 P/U(Dana 44) . I got all the bits from my local Napa store but they did not have any recommendations for the torque of the castle nuts on the tie rods.Also it seems as if I could remove both the "center link" assembly and the "drag link" assembly (both consist of two tie rods and a adjusting sleeve) and measure center to center on the studs, set up the new ones the same and reinstall and it would be more accurate than counting the number of turns into the sleeves(as someone suggested) as the new parts are not of the same manufacturer.If anyone out there has any thoughts, suggestions,specs, or ideas that would be great!!
Thanks - Jeff
59Apache4WD is offline   Reply With Quote
Old 02-19-2005, 03:03 PM   #2
59Apache4WD
I got some info but??? 45-50 ft/lbs sound right for the castle nuts?
Old 02-28-2005, 08:32 AM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
That sounds about right.
I have never used a torque wrench for tie rod ends, just made them good and tight.
Also check for slop in the steering gear.
This is a common source for play in the steering.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
