Old 02-19-2005, 07:07 PM   #1
hugger67
transfer case drop
i'm trying to find out how far you guys have dropped your transfer case on a 87 and up era truck let me know what you guys have done thanks in advance
hugger67 is offline   Reply With Quote
Old 02-20-2005, 06:04 AM   #2
Mudder
Mudder's Avatar
I dropped mine below the frame using the spacers that come on the bolts. Its about 1 inch below the frame now. Just be careful when you drop the case down u dont trash your distibutor. It will hit the firewall if you drop the case too low.The original bolts come with some sleeves on them. Thats what I used for spacers.
Mudder is offline   Reply With Quote
Old 02-20-2005, 01:22 PM   #3
soleeagle
soleeagle's Avatar
Yep same here on my 85
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 02-20-2005, 04:52 PM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
What kind of truck? Trany? tcase?
If you have a Chevy, you can clock (rotate) the tcase to move the front output lower. This only works on the newer tcase that has the single bolt circle and is easiest with a 208 tcase. The 205 has a notch for the shift lever so you need to make a new notch or get a 208 adapter and make a notch.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 02-22-2005, 07:48 PM   #5
1972
Majician
1972's Avatar
I wouldn't lower a t-case, especially using factory spacers. If you lower a t-case it will hurt you front driveshaft cv joint operating angle. If you use the factory spacers it will crack your frame, unless you just get groceries and drive to the mall.
1972 is offline   Reply With Quote
Old 02-22-2005, 09:47 PM   #6
1FaastC10
1FaastC10's Avatar
agreed on the frame cracks by dropping it with that method. but as for the cv... the only good reason to drop the case is because the truck is lifted, so the cv should remain usable.
1FaastC10 is offline   Reply With Quote
