Old 02-22-2005, 04:30 PM   #1
jalste
rust converter
Has anybody used these new water based rust converters if so are they any good and will I have problems with my paint job later
thanks for any help!
jalste is offline   Reply With Quote
Old 02-22-2005, 04:36 PM   #2
XXL
Señor Member
XXL's Avatar
My truck has been using water based rust convertor for years... now if I could just get it converted back to unoxidized steel
</couldn't resist>
XXL is offline   Reply With Quote
Old 02-22-2005, 05:21 PM   #3
72 Cheyenne402
72 Cheyenne402's Avatar
I've never heard of rust converter???? Water based????
72 Cheyenne402 is offline   Reply With Quote
Old 02-22-2005, 05:40 PM   #4
jalste
Well the label makes you belive it kills the rust what I see it turns steel black sort of like blueing on a gun just wanted to know if anybody had used something like this
Old 02-22-2005, 07:04 PM   #5
I used some stuff from Wally world. It seems to be OK. Not sure it it is"water" based or not. I don't have any handy at the moment, but I used it for a coating on my frame and cab as I cleaded it up, then painted them. It's only been about 2 years, and thruck hasn't seem much road use, so I don't know whether it is all it says it is. Nothing has come back or spread in the areas I used it though. I did not get it as a miracle metal saver, just something to hopefully slow/deter the rust process. If it looked bad, I replaced the metal, then coated it with good paint. I like using the Eastwood Rust Encapsulator, while others like POR.
Where I used it mostly was to protect things till I got it cleaned and painted well. Before I had a shop, Things would corrode instantly here in Mississippi, so it gave me a little help preventing things from aging between working session on my truck.
Old 02-22-2005, 11:23 PM   #6
mr402
I've used 2 rust converters that work pretty well. Ospho and Rustmort. The Jasco stuff leaves something to be desired. Neither is water based though. They're actually some kind of acid and will etch the metal as well. You can use water to clean up though. If you use this stuff make certain you've got a good respirator and eye protection. Have plenty of water near by in case you get some on your skin. It does flush right off. As long as you take reasonable precautions you won't have any trouble.
mr402 is offline   Reply With Quote
Old 02-22-2005, 11:47 PM   #7
arkracing
Weekend Warrior
I use Eastwoods Rust "Converter":
OxiSolve and
Rust Dissolve
http://www.eastwood.com/jump.jsp?ite...mType=CATEGORY
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 02-23-2005, 09:24 AM   #8
jalste
Hey sound like the stuff might work ok, I´m sandblasting everything first so I¨m using it as Palf70step did to keep things from rusting between sesions.
Thanks and I keep in touch
