Old 02-23-2005, 01:56 AM   #1
HerLonghorn71
HerLonghorn71's Avatar
dana 60 gears
I need a lower set of gears for the dana 60 in my longhorn.It has 4.10 gears now and i would like to find somthing way lower to get better gas mileage.Any suggustions or a ratio that we should use in it?any place to get the gears at?The truck is a 350 with a th350 trans and we are running 265/75-r16 tires on it.Thanks crystal
HerLonghorn71 is offline   Reply With Quote
Old 02-23-2005, 02:09 AM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
They have 3.54s made just for that. Will cost you the gears and a new carrier though.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 02-23-2005, 02:31 AM   #3
1969 GMC
1969 GMC's Avatar
nope, your current carrier will work. the split is 4.10 and down, and 4.56 and up. just need the gears.
EDIT: I'm not sure if I'm reading your question right...lower gears would be 4.56's. But I don't see how that would get better mpg (except in town). If you want 4.56's, you need a new carrier.
If you want higher gears, you are good to go on the carrier.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-23-2005, 04:13 AM   #4
3 on the tree
they put 3.54s in some 3/4 ton burbs.
3 on the tree is offline   Reply With Quote
Old 02-23-2005, 08:37 AM   #5
GMC AMI
GMC AMI's Avatar
1969 GMC, she means lower number or a higher gear ratio. Crystal, IMO you should run at least 308's with your present set-up. The truck will most likely put the speedo needle in the p of the MPH at wide open, Gas mileage will improve.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 02-23-2005, 10:59 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
big block c20s came with 3.54 rear gears in the dana 60s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
