Old 02-23-2005, 05:24 AM   #1
4bynut
4bynut's Avatar
TRANNY & TRANSFER CASE QUESTION
I'm looking at buying a 1967 K20 that still has the original 4sp. and rockwell transfer case. And what I need to know is if a NP205 that came off a 4sp. will be a direct swap. Thank's in advance Jason.
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 02-23-2005, 08:12 AM   #2
Blazer1970
Blazer1970's Avatar
You would need to use the newer SM465/adapter/NP205 combo together. A 205 will not work with your SM420.
Blazer1970 is offline   Reply With Quote
Old 02-23-2005, 06:08 PM   #3
1969K10
1969K10's Avatar
Leave the Rockwell in there, its an awesome X-fer
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-23-2005, 08:06 PM   #4
1969 GMC
1969 GMC's Avatar
I don't know about "awesome" but I would just run it until it dies (and it will if you drive it...ask me how I know). Then replace it with a SM465/NP205 combo and sell the SM420 to a Jeeper.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-23-2005, 09:13 PM   #5
4bynut
4bynut's Avatar
Thank's for the help guy's. If I end up buying the truck, I'll drive it some before I decide. The owner claims it works fine and the tranny & transfer case were rebuilt by PO. PO also installed a new clutch & pressure plate. It'll still need PB and PS added. Thank's again for the help. Jason
Old 02-23-2005, 07:47 PM   #6
Prerunner1982
Prerunner1982's Avatar
man those sm420s and rockwell 221 are crap.. buy yourself the 465 and 205 and send the 420 and 221 to me... you can even pay me to take them off your hands...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-23-2005, 09:52 PM   #7
Americanrider
The rocks are a bit noisy at high speed, but just about bomp-proof!
Americanrider is offline   Reply With Quote
Old 02-25-2005, 05:24 AM   #8
4bynut
4bynut's Avatar
Has anyone had any luck quieting them. Maybe using a synthetic oil or some kind of additive. Thank's again Jason
Old 02-25-2005, 01:26 PM   #9
Americanrider
I used plain 'ol 80-90, but once I get the floorpan cleaned from years of neglect I'm going to undercoat the bottom of the cab. Then work on the interior floor, a liner w/ carpet would help mine a great deal. I'm running 4.56's so anything above 50 is Hi-speed for me. Next time I re-lube I'll try something better.
