Old 02-25-2005, 09:36 AM   #1
djracer
djracer's Avatar
WTB Vortec Heads
A Buddy of mine is looking for a set of 96 up chevy truck 350 heads. He just needs good castings he will freshen them up.
Let me know what you have!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-25-2005, 11:31 AM   #2
Deuce
Deuce's Avatar
Are those the center bolt style valve covers?? Are they a good performance head??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 02-25-2005, 12:33 PM   #3
Jason915
Yep centerbolt heads and they do flow well and have a high effecient quick burn combustion chamber. You have to run a different intake because the center bolts are angled different. Vortech perform alot better than most other factory castings and you can score them real cheap. Downside to using them is you have to buy a $200.00 intake to work with them and IMO they have junky valve guides, springs, seals.
Jason915 is offline   Reply With Quote
Old 02-25-2005, 04:00 PM   #4
djracer
djracer's Avatar
Jason915
You are almost right but they actually don't have any bolts in the center of the intake at all! They have 4 bolts front and 4 bolts rear at a totally differant angle than other heads. when the intake is on the motor the intake bolts are totaly vertical to the ground! I think they are the only way to go if you aren't going to spend big bucks on a set of heads!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-25-2005, 04:40 PM   #5
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
My friend has some Vortecs for sale I'll get the specs.... as far as intakes go all you need is this http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW It's just like a Victor JR and works great on my Vortec
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
